Jetting Webers on 2.7 911 engine., Tuning. |
914Toy |
Oct 5 2018, 10:52 AM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I recently installed a "double" Innovative air/fuel (A/F) gauge with sensors in both headers of my 1977 2.7 911 engine, which is stock except for: ignition, Weber carbs, reground cams (modified SC) for spirited street performance with the carbs, and exhaust headers (MB911). The A/F gauge has assisted final tuning, including fine balancing of the carbs (well worth it).
Ignition is Clewett crank fire with ignition timing set at: 10 deg. idle 800 rpm, 29 deg at 3000 rpm, and 33 deg at 6000rpm. Carbs are Weber 40IDA's with 34 main chokes and tall secondary chokes. Jets are: 145 main's, 180 air correction's, F3 emulsion tubes, and 60 idle's. Engine is running very smoothly at all rpm's, no carb "spitting" or exhaust popping, no hesitation under any acceleration, and instant accelerator response with plenty of power. In other words, running great. However, A/F's are not perfect with 10.5 at idle, 12.5 to 13 at cruising, and high 13's up hill WOT. On a recent uninterrupted 180 miles run on 101 at 3400rpm (78mph), fuel consumption was 24miles per gallon (IMG:style_emoticons/default/smile.gif) I have discussed the A/F ratio issue with several carb "experts" - mostly Old School guys. Consensus is my numbers are as good as it gets vs. near perfect 14.7 A/F one can expect from EFI. Any comments will be welcome. |
IronHillRestorations |
Oct 6 2018, 08:11 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You can lean it out a bit by just opening the air bypass screws a little. Do you have a STE air flow meter? If so, start by making sure they are pulling the same amount of air, and then open up 1/4 - 1/2 turn each and see if it helps.
Alternately you could close the mixture screws a very small amount each, like 1/8 a turn. To be honest though, I'd say you are in the range especially if your gas isn't the best. As long as you aren't fouling plugs, I'd say don't do much, if anything. Your ignition is a primo system, which is a plus for carbs. Years ago 12.5 - 13 was considered very good, but that was before you could put an AF meter in the dash, which kinda makes it easier to think you can get it better, when it's really pretty good as is. |
porschetub |
Oct 7 2018, 12:38 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You can lean it out a bit by just opening the air bypass screws a little. Do you have a STE air flow meter? If so, start by making sure they are pulling the same amount of air, and then open up 1/4 - 1/2 turn each and see if it helps. Alternately you could close the mixture screws a very small amount each, like 1/8 a turn. To be honest though, I'd say you are in the range especially if your gas isn't the best. As long as you aren't fouling plugs, I'd say don't do much, if anything. Your ignition is a primo system, which is a plus for carbs. Years ago 12.5 - 13 was considered very good, but that was before you could put an AF meter in the dash, which kinda makes it easier to think you can get it better, when it's really pretty good as is. (IMG:style_emoticons/default/agree.gif) think the OP is in the right range,on the rich side is a safe move with any aircooled engine on carbs IMO. Perry made good points,if your idle jets are spot on its important to stay in the range of 2.5 turns for the mixture screws ,the air bleeds are handy for that final low speed balance between throats, adjustments are usually small . The low speed circuit is far more importance to get sorted because that is your driving range. Don't attempt to tune carbs unless the engine is tuned well to start with,ask me how I know ????. |
Lo-Fi Version | Time is now: 28th April 2024 - 05:57 PM |
