Jetting Webers on 2.7 911 engine., Tuning. |
914Toy |
Oct 5 2018, 10:52 AM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I recently installed a "double" Innovative air/fuel (A/F) gauge with sensors in both headers of my 1977 2.7 911 engine, which is stock except for: ignition, Weber carbs, reground cams (modified SC) for spirited street performance with the carbs, and exhaust headers (MB911). The A/F gauge has assisted final tuning, including fine balancing of the carbs (well worth it).
Ignition is Clewett crank fire with ignition timing set at: 10 deg. idle 800 rpm, 29 deg at 3000 rpm, and 33 deg at 6000rpm. Carbs are Weber 40IDA's with 34 main chokes and tall secondary chokes. Jets are: 145 main's, 180 air correction's, F3 emulsion tubes, and 60 idle's. Engine is running very smoothly at all rpm's, no carb "spitting" or exhaust popping, no hesitation under any acceleration, and instant accelerator response with plenty of power. In other words, running great. However, A/F's are not perfect with 10.5 at idle, 12.5 to 13 at cruising, and high 13's up hill WOT. On a recent uninterrupted 180 miles run on 101 at 3400rpm (78mph), fuel consumption was 24miles per gallon (IMG:style_emoticons/default/smile.gif) I have discussed the A/F ratio issue with several carb "experts" - mostly Old School guys. Consensus is my numbers are as good as it gets vs. near perfect 14.7 A/F one can expect from EFI. Any comments will be welcome. |
mb911 |
Nov 8 2018, 05:01 AM
914 Guru Group: Members Posts: 6,815 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Interesting.. I actually need a few of those cup washers. Anyone know where to get them?
914Toy |
Nov 8 2018, 09:54 AM
Interesting.. I actually need a few of those cup washers. Anyone know where to get them? I do not believe you NEED them, other than for originality optics purposes. They have no useful function other than perhaps a little help to prevent the screws vibrating loose - unlikely with the springs doing this. The possibility of the intake vacuum pulling air through the threads is minuscule and I would judge as extremely unlikely be enough to have any performance impact. One source suggests these O rings were an attempt to show good faith to environmentalists - per discussion on PP (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 09:08 PM |
