Putting FI back on a 2.0l |
Tdskip |
Oct 6 2018, 07:13 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning and happy Saturday.
I bought a low mile rebuilt 2.0l engine that has carbs but also came with a full FI set up up that supposed worked fine before someone got an overdose of testosterone and felt the urge to tweak the fuel system (prior owners description (IMG:style_emoticons/default/evilgrin.gif) ). Anyone put FI back on a car? Seems fairly straight forward but.... |
mgphoto |
Oct 6 2018, 11:05 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Check to see if the cam is FI. Carb cams different animal and will not run well with D-Jet.
bbrock |
Oct 6 2018, 11:15 AM
Check to see if the cam is FI. Carb cams different animal and will not run well with D-Jet. (IMG:style_emoticons/default/agree.gif) +1 The cam is often changed when engines are converted to carbs. It's the only reason I've put restoring my original FI on the back burner. |
Tdskip |
Oct 6 2018, 12:47 PM
Check to see if the cam is FI. Carb cams different animal and will not run well with D-Jet. (IMG:style_emoticons/default/agree.gif) +1 The cam is often changed when engines are converted to carbs. It's the only reason I've put restoring my original FI on the back burner. Oh, well that is a good consideration. I have no idea. |
Lo-Fi Version | Time is now: 24th April 2024 - 10:42 PM |
