Putting FI back on a 2.0l |
Tdskip |
Oct 6 2018, 07:13 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning and happy Saturday.
I bought a low mile rebuilt 2.0l engine that has carbs but also came with a full FI set up up that supposed worked fine before someone got an overdose of testosterone and felt the urge to tweak the fuel system (prior owners description (IMG:style_emoticons/default/evilgrin.gif) ). Anyone put FI back on a car? Seems fairly straight forward but.... |
dr914@autoatlanta.com |
Oct 10 2018, 10:24 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
very easy to reinstall just hope that they did not change the camshaft. You will need new injector seals, new vacuum line kit, new upper fuel line kit, new intake runner boots and intake blocks, new ignition points and condenser, new air cleaner, new head temp sensor new fuel filter, new throttle body gasket, new cold start gaskets, and as previously stated test the components. clean the trigger points and recap, evacuate the pressure sensor check the fuel pump for leaks, test the injectors, then you should be all set
Good morning and happy Saturday. I bought a low mile rebuilt 2.0l engine that has carbs but also came with a full FI set up up that supposed worked fine before someone got an overdose of testosterone and felt the urge to tweak the fuel system (prior owners description (IMG:style_emoticons/default/evilgrin.gif) ). Anyone put FI back on a car? Seems fairly straight forward but.... |
Lo-Fi Version | Time is now: 26th April 2024 - 08:02 PM |
