Putting FI back on a 2.0l |
Tdskip |
Oct 6 2018, 07:13 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning and happy Saturday.
I bought a low mile rebuilt 2.0l engine that has carbs but also came with a full FI set up up that supposed worked fine before someone got an overdose of testosterone and felt the urge to tweak the fuel system (prior owners description (IMG:style_emoticons/default/evilgrin.gif) ). Anyone put FI back on a car? Seems fairly straight forward but.... |
jcd914 |
Oct 11 2018, 05:01 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The cams with higher lift and longer duration and overlap create irregular intake vacuum.
The FI does not handle the vacuum pulses and irregular air flow very well. A mild carb cam you may just get poor idle quality and poor low rpm drivability. The more radical the cam the worse the FI handles it. Personally I would probably take the chance since the process is reversible. I might take the time to measure the cam lift, duration and timing. Good luck Jim |
Lo-Fi Version | Time is now: 26th April 2024 - 11:25 AM |
