Putting FI back on a 2.0l |
Tdskip |
Oct 6 2018, 07:13 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning and happy Saturday.
I bought a low mile rebuilt 2.0l engine that has carbs but also came with a full FI set up up that supposed worked fine before someone got an overdose of testosterone and felt the urge to tweak the fuel system (prior owners description (IMG:style_emoticons/default/evilgrin.gif) ). Anyone put FI back on a car? Seems fairly straight forward but.... |
jcd914 |
Oct 11 2018, 05:01 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The cams with higher lift and longer duration and overlap create irregular intake vacuum.
The FI does not handle the vacuum pulses and irregular air flow very well. A mild carb cam you may just get poor idle quality and poor low rpm drivability. The more radical the cam the worse the FI handles it. Personally I would probably take the chance since the process is reversible. I might take the time to measure the cam lift, duration and timing. Good luck Jim |
914_teener |
Oct 12 2018, 02:19 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The cams with higher lift and longer duration and overlap create irregular intake vacuum. The FI does not handle the vacuum pulses and irregular air flow very well. A mild carb cam you may just get poor idle quality and poor low rpm drivability. The more radical the cam the worse the FI handles it. Personally I would probably take the chance since the process is reversible. I might take the time to measure the cam lift, duration and timing. Good luck Jim You can measure both duration and lift with the cam in the engine. It will take some measuring...effort....and math. It can be done. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:23 AM |
