timing issue, timing light stops flashing for a split second every few seconds |
DRPHIL914 |
Oct 6 2018, 09:08 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so its missing every few seconds or so.
like when the heart skips a beat. So how or why would this happen- is it the points module?(hot spark) , seems like the most likely thing. I am going to put the 123ignition distributor in tomorrow, and it will be interesting to see if it still happens. that will eliminate the fi points plate and the hotspark module in the old distributor. So has anyone else ever seen this when setting the timing on their car?? if so what did you conclude? |
Dave_Darling |
Oct 7 2018, 10:55 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Since my car did not misfire or run any differently when the light dropped, I concluded that the problem was with the timing light. Most likely with the pickup clamped around the plug wire. Moving and repositioning the pickup usually fixed the problem--for that occurrence.
--DD |
Lo-Fi Version | Time is now: 8th May 2024 - 10:27 AM |
