Early handbrake not setting and button stuck in |
Ferg |
Oct 7 2018, 03:44 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I have an early handbrake setup. Today I set it like normal push the button in pull up and release button but the button was stuck down.
The brake is still grabbing and I can reach under the handle and with my fingers manually set the pin to grab the notches so yhe brake stays set. But without the button popping back out it will not stay “set” I tried to pull the button out carefully with plyers and I also tried to move the rod inside the handle with no luck. Anything else to try before I pull it out? What is the cause for the jam? Thanks |
mgphoto |
Oct 7 2018, 04:28 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The return sping is broken, somebody here makes a fix.
FlacaProductions |
Oct 7 2018, 04:47 PM
Senior Member Group: Members Posts: 1,571 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Oct 7 2018, 04:49 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914rubber also has those springs. It might just be corroded and need cleaning and lube.
Ferg |
Oct 7 2018, 05:45 PM
Early brake
Appears that tangerine racing is making a workaround I will call Chris and Ed Monday http://www.914world.com/bbs2/index.php?sho...328531&st=0 |
Mikey914 |
Oct 7 2018, 09:32 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Different spring.
Lo-Fi Version | Time is now: 11th May 2024 - 04:16 AM |
