It’s 2018 where are the big brake kits, DIY big brake kits |
widebody914 |
Oct 8 2018, 12:42 AM
Newbie Group: Members Posts: 15 Joined: 26-December 17 From: Mesa,AZ Member No.: 21,727 Region Association: Southwest Region |
Hey everyone just trying to reach out and get some diy big brake kit ideas. It’s 2018 and I don’t get why our options are still big reds or switch over to 911. I’m looking to do a willwood setup on a 914-4 suspension. Has anyone done this? Trying to save some coin and time.
Thanks, Trevor (group5 v8 914) |
ConeDodger |
Oct 13 2018, 12:50 PM
Apex killer! Group: Members Posts: 23,552 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I was going to say mine work well, but now that we’ve seen the car, you need something like PMB is coming out with. Mine is Ferrari 308/Alfa alloy fronts, and PMB alloy 914-6 rears.
The new PMB calipers, without the other things you’ll need to install them, will be in the neighborhood of $3500.00. But you’ll by god stop! Even that monster! Which looks pretty trick by the way... (IMG:style_emoticons/default/evilgrin.gif) Attached image(s) |
Mueller |
Oct 13 2018, 03:07 PM
I was going to say mine work well, but now that we’ve seen the car, you need something like PMB is coming out with. Mine is Ferrari 308/Alfa alloy fronts, and PMB alloy 914-6 rears. The new PMB calipers, without the other things you’ll need to install them, will be in the neighborhood of $3500.00. But you’ll by god stop! Even that monster! Which looks pretty trick by the way... (IMG:style_emoticons/default/evilgrin.gif) As cool as those new calipers look, the rotors are way too small for those 18" wheels. |
mgp4591 |
Oct 13 2018, 04:10 PM
914 Guru Group: Members Posts: 5,363 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I was going to say mine work well, but now that we’ve seen the car, you need something like PMB is coming out with. Mine is Ferrari 308/Alfa alloy fronts, and PMB alloy 914-6 rears. The new PMB calipers, without the other things you’ll need to install them, will be in the neighborhood of $3500.00. But you’ll by god stop! Even that monster! Which looks pretty trick by the way... (IMG:style_emoticons/default/evilgrin.gif) As cool as those new calipers look, the rotors are way too small for those 18" wheels. They're radial mounted so you may be able to change the adapter size and bolt em up to the Carrera 24mm rotors. Other rotors with increased diameter are questionable so you might have to go to a full on 918 setup! (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 09:22 PM |
