WTB - Rear Brake Retain Pins, Larger Pins in the rear - "901 351 913 14" |
ctc911ctc |
Oct 8 2018, 08:13 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
WTB '74, 2.0, Rear Caliper Disk Pad Retaining Pins (need 4)
I sent the calipers to PMB and they came back in near perfect condition - WOW The retaining hardware was a mess. Since this IS my first 914 brake rebuild Rodeo, I assumed (this is when you get in trouble) that all of the pictures of the disk brake pads and the associated hardware that describe the car and are guaranteed to fit would have this hardware. Nope, not the case. hardware will fit Front disks only. So, I threw away (yup, I am owning this) the pins (they did not look like they would ever work right again, 30 years of storage rust) and I am in need of 4. May thanks in advance, and if you got this far thank you for reading, I needed this therapy after scouring the web for a vendor with no luck. |
KevinW |
Oct 8 2018, 10:38 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I think I have some. I’ll check when I get home from work.
Kevin Of all the ones that I have I found two good ones (top) the rest look like the ones on the bottom. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 08:36 PM |
