WTB - Rear Brake Retain Pins, Larger Pins in the rear - "901 351 913 14" |
ctc911ctc |
Oct 8 2018, 08:13 AM
Senior Member Group: Members Posts: 891 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
WTB '74, 2.0, Rear Caliper Disk Pad Retaining Pins (need 4)
I sent the calipers to PMB and they came back in near perfect condition - WOW The retaining hardware was a mess. Since this IS my first 914 brake rebuild Rodeo, I assumed (this is when you get in trouble) that all of the pictures of the disk brake pads and the associated hardware that describe the car and are guaranteed to fit would have this hardware. Nope, not the case. hardware will fit Front disks only. So, I threw away (yup, I am owning this) the pins (they did not look like they would ever work right again, 30 years of storage rust) and I am in need of 4. May thanks in advance, and if you got this far thank you for reading, I needed this therapy after scouring the web for a vendor with no luck. |
Luke M |
Oct 8 2018, 11:40 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I believe these are the late 914 rear caliper pins.
The early pins are slightly different and these will not work in the early/914-6 rears. If the others can't help you let me know. Attached image(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:51 PM |
