Where does this hose connect?, I have a hose only connected on one end and would like to know where it connects |
tsvo |
Oct 9 2018, 05:21 AM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973, 1.7. It was idling low/stalling. I noticed the red hose in the picture is no longer attached on the one end. (Not sure if the two are related, but it's a starting point)
Can anyone tell/show me where it attaches? Any help is appreciated, it saves me the time of looking it up. Regards, Terry |
TheCabinetmaker |
Oct 9 2018, 12:02 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You must have me on ignore Jeff, or missed my post?
JeffBowlsby |
Oct 9 2018, 01:06 PM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You must have me on ignore Jeff, or missed my post? Hi Curt...No, not on ignore, I saw it. Its just not clear that the two sections of red hose in the photo are of the same hose. Any 40+ year old vacuum hoses should be replaced anyways, as they are probably not sealing well to their ports. |
tsvo |
Oct 9 2018, 02:50 PM
You must have me on ignore Jeff, or missed my post? Hi Curt...No, not on ignore, I saw it. Its just not clear that the two sections of red hose in the photo are of the same hose. Any 40+ year old vacuum hoses should be replaced anyways, as they are probably not sealing well to their ports. Jeff, yes it is the same hose. Sorry for the confusion. I found the spot where it should connect to the head. It clearly does need to be replaced though. It slipped on very easily. I doubt it is sealed well. Thanks for you help. Terry |
Jamie |
Oct 9 2018, 06:42 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
You must have me on ignore Jeff, or missed my post? Hi Curt...No, not on ignore, I saw it. Its just not clear that the two sections of red hose in the photo are of the same hose. Any 40+ year old vacuum hoses should be replaced anyways, as they are probably not sealing well to their ports. Jeff, yes it is the same hose. Sorry for the confusion. I found the spot where it should connect to the head. It clearly does need to be replaced though. It slipped on very easily. I doubt it is sealed well. Thanks for you help. Terry I recently bought the complete hose set that George has assembled at Automobile Atlanta, it was very time saving to have all the sizes and lengths in a single order. They were not all color coded to originals, but they were reasonably priced, sized to fit and cured several vacuum leaks I had been chasing. (IMG:style_emoticons/default/aktion035.gif) |
tsvo |
Oct 9 2018, 06:46 PM
You must have me on ignore Jeff, or missed my post? Hi Curt...No, not on ignore, I saw it. Its just not clear that the two sections of red hose in the photo are of the same hose. Any 40+ year old vacuum hoses should be replaced anyways, as they are probably not sealing well to their ports. Jeff, yes it is the same hose. Sorry for the confusion. I found the spot where it should connect to the head. It clearly does need to be replaced though. It slipped on very easily. I doubt it is sealed well. Thanks for you help. Terry I recently bought the complete hose set that George has assembled at Automobile Atlanta, it was very time saving to have all the sizes and lengths in a single order. They were not all color coded to originals, but they were reasonably priced, sized to fit and cured several vacuum leaks I had been chasing. (IMG:style_emoticons/default/aktion035.gif) Thanks Jamie. I'll check it out. That would make things much easier. |
Lo-Fi Version | Time is now: 20th April 2024 - 12:54 AM |
