Where does this hose connect?, I have a hose only connected on one end and would like to know where it connects |
tsvo |
Oct 9 2018, 05:21 AM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973, 1.7. It was idling low/stalling. I noticed the red hose in the picture is no longer attached on the one end. (Not sure if the two are related, but it's a starting point)
Can anyone tell/show me where it attaches? Any help is appreciated, it saves me the time of looking it up. Regards, Terry |
euro911 |
Oct 10 2018, 10:34 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If the hoses have enough slack, you can try trimming the ends past where they're cracked (regular maintenance). One should check the fuel hoses frequently as well.
Another member out here with a '73 1.7L was exhibiting the same issue a couple weeks ago. We sniped off cracked hose ends, adjusted dwell & timing and got it running, but also found the MPS' diaphragm was shot (with a Mighty-Vac). The member had already set up an appointment with a shop to perform a valve adjustment, oil change, etc. the following week, so we stopped where we were and he'll let the mechanic tackle the rest. |
Lo-Fi Version | Time is now: 24th April 2024 - 02:30 AM |
