WTB a couple little switches & other stuff, Need door switch and handbrake switch |
barefoot |
Oct 9 2018, 04:17 PM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Need one door switch with twin mini spades that activates interior light &
one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size |
mojorisen914 |
Oct 10 2018, 08:58 AM
Visit your local strip club Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains |
Are any of these in the pic what you are looking for? If not; do you have a pic?
Mojo Need one door switch with twin mini spades that activates interior light & one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size Attached thumbnail(s) |
PCA7GGR |
Oct 10 2018, 10:26 AM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
PM me if any of these will work for you:
barefoot |
Oct 10 2018, 05:31 PM
Are any of these in the pic what you are looking for? If not; do you have a pic? Mojo Here's what I need Need one door switch with twin mini spades that activates interior light & one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size |
bandjoey |
Oct 10 2018, 10:02 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Need one door switch with twin mini spades that activates interior light & one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size Crazy enough I saw 3 spring clips in my bucket o bolts today. Will let you know in the morning. Also one door switch if the other post falls through. Bill |
carl k |
Oct 10 2018, 10:28 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
bandjoey |
Oct 11 2018, 08:55 AM
I think there are 2 kinds of clips. These and a flat slide in clip. Are these what you're looking for?
barefoot |
Oct 11 2018, 09:35 AM
barefoot |
Oct 14 2018, 05:41 AM
Bump, hoping to get several things in one shipment
Thanks for responding |
Lo-Fi Version | Time is now: 25th April 2024 - 12:07 PM |
