WTB a couple little switches & other stuff, Need door switch and handbrake switch |
barefoot |
Oct 9 2018, 04:17 PM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Need one door switch with twin mini spades that activates interior light &
one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size |
bandjoey |
Oct 10 2018, 10:02 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Need one door switch with twin mini spades that activates interior light & one switch activated by the handbrake lever with single spade also need 3 spring clips that hold the front fresh air box together also need a small triangular plate with 3 screw holes that locates the headlight rotating pivot just starting to find missing stuff during re-assembly [/size Crazy enough I saw 3 spring clips in my bucket o bolts today. Will let you know in the morning. Also one door switch if the other post falls through. Bill |
carl k |
Oct 10 2018, 10:28 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Lo-Fi Version | Time is now: 7th May 2024 - 12:26 PM |
