Papa Smurf "Refresh" Winter Project Thread, Sad update 12/30/2020 |
Racer |
Feb 25 2019, 07:06 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Do I see oil lines running up the A-Pillars? Not sure I've seen that before. Is there a special reason for that type of routing?
naro914 |
Feb 25 2019, 08:03 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Do I see oil lines running up the A-Pillars? Not sure I've seen that before. Is there a special reason for that type of routing? They're not oil lines, they are vent lines - vent from the engine to the oil tank, and vent from the oil tank to the 'catch' can in the back (which I know is way too big but the guy that built it years ago made it really nice...so we just left it). I know lots of people vent the engine to a catch can close to the engine - that's how Huey is too. But with a high compression race engine, we found it was better to vent to the oil tank (like they are designed to do), but since the tank is up front.... Its actually pretty common on bigger/high compression engines from what I've seen. I don't really like it...but when the guy that's been doing this for practically longer than I've been alive says it needs to be this way...and the engine runs flawless...I don't argue! |
naro914 |
Feb 25 2019, 08:12 AM
Curious if you have any shots of the chassis tears? I have one that I need to take care of on my track car and was hoping to see how yours was repaired. The only one I have a picture of from this work was kinda odd...it was the little section around the engine area on the drivers side that really isn't structural, more just holds the engine tray gasket. It was cracking off. We just welded it back on. (picture is tough to figure out where it is) Previously, we've cracked the rear suspension points (which is why we went with Tangerine Racing raised rear mounts), Front control arm points (which is why there are forward bars in the front trunk area) and areas around the rear wheel wells, which got extra stiffening. |
Feb 25 2019, 08:49 AM
914-6 GT in waiting Group: Members Posts: 19,247 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Curious if you have any shots of the chassis tears? I have one that I need to take care of on my track car and was hoping to see how yours was repaired. The only one I have a picture of from this work was kinda odd...it was the little section around the engine area on the drivers side that really isn't structural, more just holds the engine tray gasket. It was cracking off. We just welded it back on. (picture is tough to figure out where it is) Previously, we've cracked the rear suspension points (which is why we went with Tangerine Racing raised rear mounts), Front control arm points (which is why there are forward bars in the front trunk area) and areas around the rear wheel wells, which got extra stiffening. I’m not surprised papa needed a little help. These cars were built to be sporty drivers so it’s pretty amazing that it could handle a 300hp engine and wide tires on the track. |
Racer |
Feb 28 2019, 11:14 AM
Do I see oil lines running up the A-Pillars? Not sure I've seen that before. Is there a special reason for that type of routing? They're not oil lines, they are vent lines - vent from the engine to the oil tank, and vent from the oil tank to the 'catch' can in the back (which I know is way too big but the guy that built it years ago made it really nice...so we just left it). I know lots of people vent the engine to a catch can close to the engine - that's how Huey is too. But with a high compression race engine, we found it was better to vent to the oil tank (like they are designed to do), but since the tank is up front.... Of course they are vent lines! lol.. but that wasn't registering.. I just saw lines running out from the tank and didn't think. thank you for clarifying. |
ClayPerrine |
Feb 28 2019, 01:59 PM
Life's been good to me so far..... Group: Admin Posts: 15,423 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you do a search for "pca club race road atlanta" the first video listed has Papa Smurf in it. It is right there in the preview.
naro914 |
Mar 1 2019, 01:15 PM
naro914 |
Mar 9 2019, 09:19 AM
Not much of what was done the past week/weekend was visible, mostly wiring. Nadine made a carbon fiber dash, which looks great. Installed and started wiring the electronic kill switch, etc.
Hope this weekend to actually be fairly DONE with most stuff. AiM dash/data system going in, shifter/shift rod, finalize dash, final wiring connections, re-wrap and secure all wire harnesses,...all the little tuff now. Body panels are at the painter. |
naro914 |
Mar 9 2019, 09:35 AM
76-914 |
Mar 9 2019, 10:16 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Not much of what was done the past week/weekend was visible, mostly wiring. Nadine made a carbon fiber dash, which looks great. Installed and started wiring the electronic kill switch, etc. Hope this weekend to actually be fairly DONE with most stuff. AiM dash/data system going in, shifter/shift rod, finalize dash, final wiring connections, re-wrap and secure all wire harnesses,...all the little tuff now. Body panels are at the painter. I consider this part the "Fun" stage; no problems or "gotcha's" or problem solving yet. Everything is just perfect. New, pretty and shiny stuff still in perfect condition. BTW, Papa is beginning to take shape and I like the look. (IMG:style_emoticons/default/beerchug.gif) |
sixnotfour |
Mar 9 2019, 10:49 AM
914 Wizard Group: Members Posts: 10,416 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
KELTY360 |
Mar 9 2019, 11:03 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Mar 9 2019, 11:23 AM
Are you rebuilding the engine? I thought Peter did it not so long ago.
naro914 |
Mar 9 2019, 06:55 PM
Are you rebuilding the engine? I thought Peter did it not so long ago. It had about 80 hrs on it since the rebuild, so it was time for a refresh...which, in addition to the trans re-gearing, is part of what started this whole project. They found some scoring on a cylinder they didn’t like, so got a new p&c. For Dawe’s, a “refresh” is very thorough....check everything.... |
naro914 |
naro914 |
Mar 9 2019, 06:57 PM
Yep...all started with Nadine’s fathers daily driver....25+ years ago... |
dan10101 |
Mar 9 2019, 07:31 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
naro914 |
Mar 9 2019, 07:59 PM
"Does that thing got a Hemi??" "looks like it's pitching a tent..." 18-1" compression ratio? 128 octane? Lol!! (IMG:style_emoticons/default/av-943.gif) It’s a secret... (IMG:style_emoticons/default/beer.gif) |
naro914 |
Mar 9 2019, 08:28 PM
So the goal for tomorrow, March 10, is to have the AiM dash installed and all the electrical finished and tested, shifter installed, and everything checked and tightened. Steering column got installed today (it’s 180 degrees off!!!) as well as a lot of little electrical connections.
Getting close!! |
naro914 |
Mar 10 2019, 07:44 PM
Not much to “see” from the progress this weekend but... we hooked up and tested all the electrical stuff, and amazingly everything works, no fires, no sparks! Steering column installed, shifter, new Rix shift rod bushing, Nadine started tidying up and wrapping the wires, test fit the AiM MXL2 dash logger and started connecting some of the wires. Loose wires you see are for the CoolShirt, AiM, and the Generator warning light on the panel the AiM dash will be mounted on. Getting REALLY close!!
Lo-Fi Version | Time is now: 1st May 2024 - 05:35 PM |
