Papa Smurf "Refresh" Winter Project Thread, Sad update 12/30/2020 |
ClayPerrine |
Mar 11 2019, 06:17 AM
Life's been good to me so far..... Group: Admin Posts: 15,392 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Do you have a picture of where your transponder is mounted?
Do you have the correct transponder to match the numbers in your logbook? This is a hot topic with the T&S people these days. |
naro914 |
Mar 11 2019, 08:02 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Do you have a picture of where your transponder is mounted? Do you have the correct transponder to match the numbers in your logbook? This is a hot topic with the T&S people these days. Ill get a picture. Drivers side wheel well. And yes...number matches. Same transponder I’ve had since I started racing in 2006. |
naro914 |
Mar 11 2019, 09:28 AM
Transponder
Attached thumbnail(s) |
ClayPerrine |
Mar 11 2019, 09:32 AM
naro914 |
Mar 11 2019, 09:39 AM
Transponder Bob, Thanks for making sure the transponder is correct and working. At Sebring this year, 1/3 of the transponders came up unresolved. This caused havoc with the timing and scoring staff all weekend. Clay Well I don't know if it 'works'...green light comes on and never had a problem with it before. Sebring is always the worst - first race, lots of winter work on cars, drivers with new cars...especially the cup guys that just 'arrive and drive' and nobody pays attention to transponders. |
naro914 |
Apr 10 2019, 08:06 AM
Once again, a bit negligent on posting updates. Been a busy few weeks.
OK, where were we? Oh yeah wiring. Got what we could, done, before we made the trek up to Dawe's Motorsport Development in Stroudsburg, PA to get the engine and transmission installed. Here are a few pictures of the interior and with all the body panels before loading to head North. |
naro914 |
Apr 10 2019, 08:13 AM
At Dawe's we installed the engine and transmission.
We have a 915 trans with Vellios side shift conversion. Anyone that has had a Vellios knows they can be a bit tricky to adjust correctly. Peter Dawe's has a 'cut out' 915 housing so he can see inside while activating the internal mechanisms. you installed the entire unit in the car and go through the gears while he watches to see clearances and interference points. Make adjustments, try again, until everything shifts smoothly. Then re-install into your own case. Very slick... |
naro914 |
Apr 10 2019, 08:25 AM
Cairo94507 |
Apr 10 2019, 08:49 AM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Your car looks terrific. Great numbers too. (IMG:style_emoticons/default/beerchug.gif)
76-914 |
Apr 10 2019, 09:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Nice! Looking forward to some new video's. (IMG:style_emoticons/default/beerchug.gif)
Krieger |
Apr 10 2019, 10:03 AM
Advanced Member Group: Members Posts: 4,693 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
WOW! Awesome car!
naro914 |
Apr 14 2019, 05:22 AM
Maltese Falcon |
Apr 14 2019, 09:10 AM
Advanced Member Group: Members Posts: 4,629 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Then on to the dyno. I'll post video up when I get a chance. Not much to see...more to hear. but here's the dyno sheet. Might be hard to read: 325 whp 279 tq (we did see 285 on one pull) Not bad... That's a strong engine , 325 rwhp !! Mustang dynos are know to be conservative. I'll bet that you will see higher numbers on a Dynojet 248c ...but that engine will haul the mail (IMG:style_emoticons/default/driving.gif) Beautiful restoration and upgrade work as well (IMG:style_emoticons/default/aktion035.gif) |
ClayPerrine |
Apr 15 2019, 07:47 AM
Uh.. Bob...
Your transmission has a hell of an oil leak.... (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads/post-6073-1554905600.jpg) |
vintage914racer |
Apr 15 2019, 09:02 PM
Member Group: Members Posts: 428 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
Curious if you have any shots of the chassis tears? I have one that I need to take care of on my track car and was hoping to see how yours was repaired. The only one I have a picture of from this work was kinda odd...it was the little section around the engine area on the drivers side that really isn't structural, more just holds the engine tray gasket. It was cracking off. We just welded it back on. (picture is tough to figure out where it is) Previously, we've cracked the rear suspension points (which is why we went with Tangerine Racing raised rear mounts), Front control arm points (which is why there are forward bars in the front trunk area) and areas around the rear wheel wells, which got extra stiffening. Thanks much for sharing. I need to replace the passenger rear suspension console on my track care , but I’m having issues finding someone local-ish with the skills and desire to do so. |
Apr 16 2019, 11:20 AM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
What's the component on stand-offs from the valve cover? Looks to be part of the oil system, but what does it do?
--DD |
naro914 |
Apr 17 2019, 09:58 AM
What's the component on stand-offs from the valve cover? Looks to be part of the oil system, but what does it do? --DD Its a small oil reserve feed reservoir. It allows there to be a small reserve of oil right at the engine oil inlet so it doesn't starve under hard right hand high G loads. Since most tracks run clockwise, you end up with way more times the oil is trying to move away from the engine. In a 911, the oil is being forced INTO the engine during those turns because the tank and feed are on the right. But flipping it around in a 914, you could end up with oil starvation. Dawe's developed this many years ago after finding high HP/high grip 914's were getting oil starvation on long right hand high G turns. It's actually baffled inside too. |
ClayPerrine |
Apr 18 2019, 06:57 AM
What's the component on stand-offs from the valve cover? Looks to be part of the oil system, but what does it do? --DD Its a small oil reserve feed reservoir. It allows there to be a small reserve of oil right at the engine oil inlet so it doesn't starve under hard right hand high G loads. Since most tracks run clockwise, you end up with way more times the oil is trying to move away from the engine. In a 911, the oil is being forced INTO the engine during those turns because the tank and feed are on the right. But flipping it around in a 914, you could end up with oil starvation. Dawe's developed this many years ago after finding high HP/high grip 914's were getting oil starvation on long right hand high G turns. It's actually baffled inside too. Who sells them? I may want to put one on the monster motor....... Clay |
naro914 |
Apr 18 2019, 07:02 AM
What's the component on stand-offs from the valve cover? Looks to be part of the oil system, but what does it do? --DD Its a small oil reserve feed reservoir. It allows there to be a small reserve of oil right at the engine oil inlet so it doesn't starve under hard right hand high G loads. Since most tracks run clockwise, you end up with way more times the oil is trying to move away from the engine. In a 911, the oil is being forced INTO the engine during those turns because the tank and feed are on the right. But flipping it around in a 914, you could end up with oil starvation. Dawe's developed this many years ago after finding high HP/high grip 914's were getting oil starvation on long right hand high G turns. It's actually baffled inside too. Who sells them? I may want to put one on the monster motor....... Clay Dawe's fabricates them. I can ask how much they would sell them for |
ClayPerrine |
Apr 18 2019, 02:13 PM
What's the component on stand-offs from the valve cover? Looks to be part of the oil system, but what does it do? --DD Its a small oil reserve feed reservoir. It allows there to be a small reserve of oil right at the engine oil inlet so it doesn't starve under hard right hand high G loads. Since most tracks run clockwise, you end up with way more times the oil is trying to move away from the engine. In a 911, the oil is being forced INTO the engine during those turns because the tank and feed are on the right. But flipping it around in a 914, you could end up with oil starvation. Dawe's developed this many years ago after finding high HP/high grip 914's were getting oil starvation on long right hand high G turns. It's actually baffled inside too. Who sells them? I may want to put one on the monster motor....... Clay Dawe's fabricates them. I can ask how much they would sell them for Thanks! |
Lo-Fi Version | Time is now: 19th April 2024 - 03:56 AM |
