Tdskip |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,132 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() |
Good morning gentlemen-the engine rebuild tech weekend isn't forgotten but I wanted to see if we could get a easier to pull off tech day going on one or more common tasks that people would like to see.
- valve adjustment - FI component testing - installing in tuning dual carbs - adding a front or rear sway bar - rear caliper brake adjustments - installing turbo tire rods Any of those jump out as worthwhile topics? Other ideas? |
914-300Hemi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 874 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California ![]() |
I would like to see a valve job done.
Tdskip |
Hi there. Valve adjustment (easy) or a replacement of the valves with the head off the engine ( much more involved )?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,910 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Hi there. Valve adjustment (easy) or a replacement of the valves with the head off the engine ( much more involved )? Valve replacement is not a do it yourself job. If you have to replace the valves you may also need to replace seats and guides. Checking if they need replacement is a DIY job. Engine build is more like a 3 day class. It could be broken up to many smaller jobs. |
bdstone914 |
Yes- valve adjustment Yes D jet or L jet- ?? FI component testing No - installing in tuning dual carbs No. - adding a front or rear sway bar Yes. - rear caliper brake adjustments Yes - but requires alignment - installing turbo tire rods Time permitting, I can help with instruction. These should be video taped for future reference. |
bdstone914 |
ValcoOscar |
Garage Rat ![]() ![]() ![]() Group: Members Posts: 880 Joined: 19-November 13 From: SoCal: North OC / Temecula Member No.: 16,669 Region Association: Southern California ![]() |
You know I'm ALL IN in on whatever we can all agree on. Sharing knowledge is a big part of this community. Oscar |
Tdskip |
(IMG:style_emoticons/default/popcorn[1].gif) You know I'm ALL IN in on whatever we can all agree on. Sharing knowledge is a big part of this community. Oscar And that's why we love you. What would you like to see Oscar? Let's put a valve adjustment on the list. Would leaking oil return tubes be a good one? |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,524 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() |
That's another long process, requires removing the motor and moderate tear-down to remove the heads (IMG:style_emoticons/default/dry.gif)
* Changing an alternator might be something to broach? - usually a two-man job to make it a shorter task, but it can be done by one. * Installation of new strut cartridges and/or rear shock absorbers * Installation of new ball joints and/or tie-rod ends * Shift lever/rod adjustment * Pop-up headlight adjustment and alignment |
SO.O.C914er |
Member ![]() ![]() Group: Members Posts: 340 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
I would be down for headlight adjustment and alignment....Paul. (IMG:style_emoticons/default/driving.gif) could supply burgers and beer plus man the BBQ.
Tdskip |
Hi guys-sounds like we've got enough interest to get something going, agree that the jobs need to be fairly easy to knock out.
I can arrange posting in Costa Mesa. Are Saturdays or Sundays usually better for people? |
euro911 |
Either day works for me
SO.O.C914er |
Either day works for me also. But this Sunday is the G&R swap meet so I’m assuming we are talking about a weekend in the near future.....Paul
Tdskip |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,825 Joined: 2-January 03 From: N Cal Member No.: 81 Region Association: Northern California ![]() |
Will there be shuttles from the airport? (IMG:style_emoticons/default/biggrin.gif)
914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 890 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() |
Yes, I will be running a Shuttle on my way south to OC that day. Never underestimate the reach of Oscar’s extended network! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 19th February 2019 - 05:29 AM |
