SoCal Tech Day ideas - let's get something on the calendar |
Tdskip |
Oct 10 2018, 10:18 AM
Advanced Member Group: Members Posts: 3,674 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning gentlemen-the engine rebuild tech weekend isn't forgotten but I wanted to see if we could get a easier to pull off tech day going on one or more common tasks that people would like to see.
- valve adjustment - FI component testing - installing in tuning dual carbs - adding a front or rear sway bar - rear caliper brake adjustments - installing turbo tire rods Any of those jump out as worthwhile topics? Other ideas? |
Tdskip |
Oct 10 2018, 09:38 PM
Hi there. Valve adjustment (easy) or a replacement of the valves with the head off the engine ( much more involved )?
bdstone914 |
Oct 11 2018, 06:40 AM
bdstone914 Group: Members Posts: 4,497 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi there. Valve adjustment (easy) or a replacement of the valves with the head off the engine ( much more involved )? Valve replacement is not a do it yourself job. If you have to replace the valves you may also need to replace seats and guides. Checking if they need replacement is a DIY job. Engine build is more like a 3 day class. It could be broken up to many smaller jobs. |
Lo-Fi Version | Time is now: 29th March 2024 - 09:38 AM |
