SoCal Tech Day ideas - let's get something on the calendar |
Tdskip |
Oct 10 2018, 10:18 AM
Advanced Member Group: Members Posts: 3,674 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning gentlemen-the engine rebuild tech weekend isn't forgotten but I wanted to see if we could get a easier to pull off tech day going on one or more common tasks that people would like to see.
- valve adjustment - FI component testing - installing in tuning dual carbs - adding a front or rear sway bar - rear caliper brake adjustments - installing turbo tire rods Any of those jump out as worthwhile topics? Other ideas? |
euro911 |
Oct 11 2018, 12:44 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
That's another long process, requires removing the motor and moderate tear-down to remove the heads (IMG:style_emoticons/default/dry.gif)
* Changing an alternator might be something to broach? - usually a two-man job to make it a shorter task, but it can be done by one. * Installation of new strut cartridges and/or rear shock absorbers * Installation of new ball joints and/or tie-rod ends * Shift lever/rod adjustment * Pop-up headlight adjustment and alignment |
Lo-Fi Version | Time is now: 29th March 2024 - 07:32 AM |
