Changing the window scraper on the door., How to remove the cap |
jagalyn |
Oct 10 2018, 05:08 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
I am trying to replace the outside window scraper on my 1973 914 door. I've removed the small screw from the end cap but am wondering how to get this piece loose. I've tried to pry it up but I do not want to break it anymore than I already have. Do I have to loosen the rear rail inside the door for the window glass? Also, are these still available? I've found them at AA but they are only for 70-72 cars.
Can anyone advise please? |
914_teener |
Oct 10 2018, 05:35 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There is another screw in the glass channel near the top.
Peel back the fuzzy out of the channel about an inch down and you will see it. Undo that screw and pull ths cap straight out. |
jagalyn |
Oct 10 2018, 06:05 PM
There is another screw in the glass channel near the top. Peel back the fuzzy out of the channel about an inch down and you will see it. Undo that screw and pull ths cap straight out. Thank you for your help. Can you get to it from the top without taking the door apart and the glass out? |
914_teener |
Oct 10 2018, 06:20 PM
There is another screw in the glass channel near the top. Peel back the fuzzy out of the channel about an inch down and you will see it. Undo that screw and pull ths cap straight out. Thank you for your help. Can you get to it from the top without taking the door apart and the glass out? Yes....roll the glass all the way down. Use a long phillips head screw driver. Once the screw is out pull it straight up. If you drop the screw...then you are talking the door card off. |
Lo-Fi Version | Time is now: 7th May 2024 - 12:57 PM |
