WTB: Targa Top Rear Latches |
BENBRO02 |
Oct 11 2018, 12:20 PM
Member Group: Members Posts: 480 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
The pin and hook are worn so much on one side that I can't latch the top down on the passenger side rear. The pin has a slot worn into it from years of use and the hook just slides through that slot. The hook looks like some of the metal has worn away also. Has anyone else ever had this problem?
carl k |
Oct 11 2018, 01:00 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
I tightened up a pair of loose targa latch pins by sliding a short length of vinyl tubing over the pin. It was enough to fill the hook.
-Carl |
BENBRO02 |
Oct 11 2018, 01:45 PM
I tightened up a pair of loose targa latch pins by sliding a short length of vinyl tubing over the pin. It was enough to fill the hook. -Carl Sounds like an good solution if it works. I'll try that first but mine are pretty far gone. I was thinking about having the slot filled with weld but I really need the hooks to be more pronounced too. Thanks |
sholman5 |
Oct 11 2018, 02:20 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
If that doesn't work and you need replacements. You'll probably need to specify early or late. The tops are different.
bdstone914 |
Oct 11 2018, 02:27 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have restored rear latches. Need to know the car and top year. Or post a picture of the top of the rear latch.
BENBRO02 |
Oct 11 2018, 03:36 PM
bdstone914 |
Oct 11 2018, 04:19 PM
I have restored rear latches. Need to know the car and top year. Or post a picture of the top of the rear latch. I have a 1975 I have a restored pair with new reproduction hooks and springs for $80 shipped for the pair. @BENBRO02 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 08:00 PM |
