> 914World Classifieds Rules
> WTB: Targa Top Rear Latches
BENBRO02
post Oct 11 2018, 12:20 PM
The pin and hook are worn so much on one side that I can't latch the top down on the passenger side rear. The pin has a slot worn into it from years of use and the hook just slides through that slot. The hook looks like some of the metal has worn away also. Has anyone else ever had this problem?
carl k
post Oct 11 2018, 01:00 PM
I tightened up a pair of loose targa latch pins by sliding a short length of vinyl tubing over the pin. It was enough to fill the hook.
-Carl
BENBRO02
post Oct 11 2018, 01:45 PM
QUOTE(carl k @ Oct 11 2018, 03:00 PM) *
-Carl
Sounds like an good solution if it works. I'll try that first but mine are pretty far gone. I was thinking about having the slot filled with weld but I really need the hooks to be more pronounced too.
Thanks
sholman5
post Oct 11 2018, 02:20 PM
Kraut burner
If that doesn't work and you need replacements. You'll probably need to specify early or late. The tops are different.
bdstone914
post Oct 11 2018, 02:27 PM
bdstone914
I have restored rear latches. Need to know the car and top year. Or post a picture of the top of the rear latch.
BENBRO02
post Oct 11 2018, 03:36 PM
QUOTE(bdstone914 @ Oct 11 2018, 04:27 PM) *
I have a 1975
bdstone914
post Oct 11 2018, 04:19 PM
bdstone914
QUOTE(BENBRO02 @ Oct 11 2018, 02:36 PM) *
I have a 1975
I have a restored pair with new reproduction hooks and springs for $80 shipped for the pair.
@BENBRO02
- Lo-Fi Version Time is now: 16th April 2024 - 09:44 AM
