original external mirror bolts |
milwlandrover |
Oct 11 2018, 01:17 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Does anyone know what size bolt were used in the original external mirrors? I found a mirror to replace my cheap plastic/rubber mirrors but it only used one bolt which the previous owner had used a plastic anchor to make it fit....
thanks again. |
worn |
Oct 11 2018, 01:35 PM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Does anyone know what size bolt were used in the original external mirrors? I found a mirror to replace my cheap plastic/rubber mirrors but it only used one bolt which the previous owner had used a plastic anchor to make it fit.... thanks again. I am pretty sure six mm. Two captive nuts inside the door skin. I hope the plastic anchor is in a hole covered by the mirror. |
JFG |
Oct 11 2018, 01:43 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
2 m6 countersunk but with a slight domehead
Oct 11 2018, 02:03 PM
They are stainless steel. Same as the door screws. 914 rubber has them if you are already doing an order.
milwlandrover |
Oct 12 2018, 06:55 AM
Thanks everyone! bought the bolt and pad and cuz the order was small I also bought interior carpeting. Getting closer to being a real car everyday.
Lo-Fi Version | Time is now: 25th April 2024 - 07:19 PM |
