76 914 gets a Raby 2270 |
tailwind22 |
Oct 12 2018, 06:16 PM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
I wanted to share my progress on a Raby 2270 install in my 76 914. I purchased a new "old" Raby 2270, 0 hours, build date 2010 off of this board in April. Hade several discussions with Jake and he gave me good counsel in recommending that I replace the valve springs due the length of time the motor was in storage. He was right, it was interesting to observe the uncompressed length of the old springs due to some sitting in a compressed mode. Here is the car before, 2.0L D Jet FI, the new motor, new low pressure fuel pump with SS fuel line in the tunnel and underside of motor. Went with European Racing Headers with a coating. If I want heat I may move to Chris Foley's header system in the future. Have a dual fan Setrab oil cooler and remote oil filter. Decided to go down the rabbit hole a bit further with PMB restored brakes and 5 lug conversion. They are things of beauty. Also upgraded all suspension bushings to street performance grade, new Koni front shocks and plenty of fresh powdercoat. Hopefull will get it fired up tomorrow and will continue to post on progress. Been a fun project so far.
Attached thumbnail(s) Attached image(s) |
tailwind22 |
Oct 12 2018, 06:18 PM
More pics....
Attached thumbnail(s) |
worn |
Oct 12 2018, 06:21 PM
can't remember Group: Members Posts: 3,143 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
You have reason to be proud. I like the 76 model. Yours looks super.
seanery |
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
nice car! that'll be a fun one!
worn |
Oct 12 2018, 06:23 PM
Jamie |
Oct 12 2018, 07:29 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Several observations, how uncluttered the flat 4 is when fitted with carbs rather than all the hoses/air cleaner with FI. What purpose is the pair of plastic lines that are in the under tank area, and while the tank is out, do yourself a big handling favor and install a sway bar. Also there should be a fuel filter between the tank and fuel pump.
Mueller |
Oct 12 2018, 07:58 PM
Very nice, enjoy it.
Oct 12 2018, 08:05 PM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
E-brake?
ChrisFoley |
Oct 12 2018, 08:53 PM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Went with European Racing Headers with a coating. If I want heat I may move to Chris Foley's header system in the future. Having heat with a performance header system is a nice bonus but that shouldn't be the primary reason for choosing my exhaust system. More power and awesome sound are the best reasons. (IMG:style_emoticons/default/smile.gif) Looks like she's ready to go. Have fun! (IMG:style_emoticons/default/driving.gif) |
tailwind22 |
Oct 12 2018, 10:50 PM
You have reason to be proud. I like the 76 model. Yours looks super. I noticed the background. How many of these things do you have? The red one is a 73 2.0L that is headed to a new home in North Carolina. The Tangerine one is a real 914-6 that was started as a rotisserie restoration that I bought in an uncompleted state. My winter project. |
jcd914 |
Oct 12 2018, 11:41 PM
Several observations, how uncluttered the flat 4 is when fitted with carbs rather than all the hoses/air cleaner with FI. What purpose is the pair of plastic lines that are in the under tank area, and while the tank is out, do yourself a big handling favor and install a sway bar. Also there should be a fuel filter between the tank and fuel pump. I agree that a sway bar would be a good idea, especially with all the power you are adding. The only plastic lines I see are the brake fluid supply from reservior to the master cylinder. It looks like there is a fuel filter attached directly to the fuel pump. Jim |
kgruen2 |
Oct 13 2018, 06:22 AM
Member Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region |
Several observations, how uncluttered the flat 4 is when fitted with carbs rather than all the hoses/air cleaner with FI. What purpose is the pair of plastic lines that are in the under tank area, and while the tank is out, do yourself a big handling favor and install a sway bar. Also there should be a fuel filter between the tank and fuel pump. I agree that a sway bar would be a good idea, especially with all the power you are adding. The only plastic lines I see are the brake fluid supply from reservior to the master cylinder. It looks like there is a fuel filter attached directly to the fuel pump. Jim I've got a Raby 2270. It's a work of art and runs great. Strong mid-range and free revving. I have an artificial red line of 6000 rpm, but it still pulls strong after that if I don't watch it. As Jaimie mentioned, I have a fuel filter just before the fuel pump and one before each carb. The only issue I have is it is very cold blooded and the idle stabilizes at 950-1000 after engine warms up to normal operating temps. You will enjoy this engine. |
jmitro |
Oct 13 2018, 06:30 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
beautiful car!
tailwind22 |
Oct 13 2018, 07:05 AM
Several observations, how uncluttered the flat 4 is when fitted with carbs rather than all the hoses/air cleaner with FI. What purpose is the pair of plastic lines that are in the under tank area, and while the tank is out, do yourself a big handling favor and install a sway bar. Also there should be a fuel filter between the tank and fuel pump. I agree that a sway bar would be a good idea, especially with all the power you are adding. The only plastic lines I see are the brake fluid supply from reservior to the master cylinder. It looks like there is a fuel filter attached directly to the fuel pump. Jim You are correct Jim. I decided to retain the small filter that came with the fuel pump. I have another larger metal filter mounted on the lower firewall before the fuel line heads up into the engine bay. Yes, I wish I had added a front sway bar early in the project. |
RickS |
Oct 13 2018, 08:22 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Gorgeous ride with power to match. Lucky dog. (IMG:style_emoticons/default/smile.gif).
tailwind22 |
Nov 17 2018, 03:27 PM
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends.
wndsrfr |
Nov 17 2018, 08:20 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends. (IMG:style_emoticons/default/piratenanner.gif) You're really going to love that Raby engine--just so powerful, really brings the car to life. Consider Chris Foley's cable linkage for the carbs to be absolutely sure of getting the sync correct.... http://www.tangerineracing.com/throttlelinkage.htm |
rjames |
Nov 18 2018, 01:11 AM
I'm made of metal Group: Members Posts: 3,910 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
What happened to the underside? Looks a bit pushed in along the bottom of the center tunnel.
tailwind22 |
Nov 18 2018, 09:09 AM
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends. (IMG:style_emoticons/default/piratenanner.gif) You're really going to love that Raby engine--just so powerful, really brings the car to life. Consider Chris Foley's cable linkage for the carbs to be absolutely sure of getting the sync correct.... http://www.tangerineracing.com/throttlelinkage.htm Interestingly the one thing I am not happy with is the throttle linkage set up and in fact have ordered Chris's set up for installation this winter. Good call. |
tailwind22 |
Nov 18 2018, 09:11 AM
Lo-Fi Version | Time is now: 19th April 2024 - 02:44 PM |
