76 914 gets a Raby 2270 |
tailwind22 |
Oct 12 2018, 06:16 PM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
I wanted to share my progress on a Raby 2270 install in my 76 914. I purchased a new "old" Raby 2270, 0 hours, build date 2010 off of this board in April. Hade several discussions with Jake and he gave me good counsel in recommending that I replace the valve springs due the length of time the motor was in storage. He was right, it was interesting to observe the uncompressed length of the old springs due to some sitting in a compressed mode. Here is the car before, 2.0L D Jet FI, the new motor, new low pressure fuel pump with SS fuel line in the tunnel and underside of motor. Went with European Racing Headers with a coating. If I want heat I may move to Chris Foley's header system in the future. Have a dual fan Setrab oil cooler and remote oil filter. Decided to go down the rabbit hole a bit further with PMB restored brakes and 5 lug conversion. They are things of beauty. Also upgraded all suspension bushings to street performance grade, new Koni front shocks and plenty of fresh powdercoat. Hopefull will get it fired up tomorrow and will continue to post on progress. Been a fun project so far.
Attached thumbnail(s) Attached image(s) |
tailwind22 |
Nov 17 2018, 03:27 PM
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends.
wndsrfr |
Nov 17 2018, 08:20 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends. (IMG:style_emoticons/default/piratenanner.gif) You're really going to love that Raby engine--just so powerful, really brings the car to life. Consider Chris Foley's cable linkage for the carbs to be absolutely sure of getting the sync correct.... http://www.tangerineracing.com/throttlelinkage.htm |
tailwind22 |
Nov 18 2018, 09:09 AM
Finally did initial test drive today after tweaking a few things the last month. It is a snarly, raspy, nasty beast on the road and mega impressed with power curve. Worth the long time on the lift doing all the odds and ends. (IMG:style_emoticons/default/piratenanner.gif) You're really going to love that Raby engine--just so powerful, really brings the car to life. Consider Chris Foley's cable linkage for the carbs to be absolutely sure of getting the sync correct.... http://www.tangerineracing.com/throttlelinkage.htm Interestingly the one thing I am not happy with is the throttle linkage set up and in fact have ordered Chris's set up for installation this winter. Good call. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:28 PM |
