Compression, Not your average Engine |
Mblizzard |
Oct 16 2018, 06:44 AM
Ok so as many know, I an building my dream engine. With lots of Type 4 Store goodies including Nickies, 78 mm crank, and 102mm P/Cs, LE-200 heads and a decent cam, I am looking at where I want my compression to be.
With a normal engine and quality components it seems that 8.5 to 9.5 is about the limit before heat and detonation become issues. Don't have any measurements yet but playing around with some calculations and assuming a low deck height because I have a slight dish and or valve pockets in the pistons I could easily get to over 11 to 1. But I am think that might not be a long lasting engine. Looking at going for 10 to 10.5. Thoughts? (IMG:style_emoticons/default/blowup.gif) |
VaccaRabite |
Oct 16 2018, 08:05 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Its somewhat apples and oranges since my engine is a 2056, but in this most recent iteration I backed the compression from 9.2:1 down to 8.8:1. The engine has responded very positively to that. Not as punchy, yes, but head heat was an issue on the highway unless I kept it in 4th until about 70mph. With the slightly lower compression, I'm generating a lot less heat. (measuring heat on a Dakota Digital CHT tied to Cyl 3 spark plug.)
I think going 10:1 with the thin cylinder walls is going to be a challenge, unless you have a system in place to REALLY move that heat out of the cylinders and heads. Zach |
Lo-Fi Version | Time is now: 19th May 2024 - 07:17 AM |
