| ammason |
Jun 17 2005, 03:51 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 14-March 05 From: Sunny Honolulu Member No.: 3,758 Region Association: Hawaii |
So my 73 2.0L has an issue, but I can't track it down... 95% of the time it's great, but every once in a while, it just won't start. I have power - headlights, radio, etc; and if I push start it it starts up just fine, but 1 parking job out of 20 leaves me with nothing. No solenoid engaging, nothing but the dash lights coming on to let me know I have no oil pressure.
The five or six times this has happened I've been without a multimeter and have needed to get somewhere, so I've just pushed and gone, but it's damned annoying and one of these day's I'll get myself into a situation I can't get out of. Yesterday I had to push start it in reverse in a parking lot while blocking up traffic. It's a helluva way to impress the chicks, let me tell you... I'll do my best to test it when it happens next, but am I describing typical symptoms of a part needing to be replaced? Ignition switch? Solenoid? Bueller? Thanks! Aaron |
| bd1308 |
Jun 17 2005, 03:58 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
soloinoid....definately. i had 2 do the same exact thing.
| Rand |
Jun 17 2005, 04:03 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I wouldn't say definitely. It could be, but mine was a cracked ignition switch. Which is actually pretty common in 914s. It's not hard to test, so make sure you test before buying a new solenoid just in case.
| ammason |
Jun 17 2005, 04:17 PM
Anybody got one for sale?
| jet1 |
Jun 17 2005, 04:21 PM
Member ![]() ![]() Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
Clean all electrical connections first. grounds, battery terminals. My truck acted the same way and I thought it was the soloinoid. turned out to be a bad connection.
| Rand |
Jun 17 2005, 04:26 PM
I ruled out the solenoid in less than a minute with the old screwdriver trick. (Along with the connections, battery, and ground strap, which could all cause this symptom). It's worth a quick test to see if it cranks when you short between main power terminal and ignition switch terminal. (From red arrow to green in photo below.) Make sure the car is in neutral first of course.
(IMG:http://www.4nets.com/baldwinpowersports/images/starterscrewdriver.jpg) |
| michel richard |
Jun 17 2005, 04:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I had something a little simlilar. It was the ignition switch.
| ammason |
Jun 17 2005, 05:08 PM
Hmmm... The only way the screwdriver test will work is if I can catch it when it stops working... Like I said, most of the time it works fine, and when it works, it keps working.
I'm inclined to think it's NOT the ignition switch, as that would be intermittant at the switch, and if I tried it a bunch of times it should start with some statistical frequency. The problem is that when (start-inhibiting condition) is working, I can turn it on and off a million times just fine, and when (start-inhibiting condition) is screwy, I can turn the key a million times and it doesn't so much as click. |
| Rand |
Jun 17 2005, 05:17 PM
True, you can't test until it fails again.
I think a switch or bad connection can be as erratic as any other component. In the mean time I think you should take jet1's advice. Take the battery cables off and clean the posts and the insides of the terminals. Clean the ground strap connections well. The end that is bolted to the body isn't too bad to get to through the left rear fender if you jack the car up a bit. The transmission end is tougher though. I just hate to buy parts unless I know they're bad. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) But hey, it's easy to replace a solenoid. I'm curious... I hope you'll post results. |
| ammason |
Jun 17 2005, 05:35 PM
Yeah, I'll go through and check electrical first - it's time for valves/oil anyway.
Lo-Fi Version | Time is now: 20th November 2026 - 07:52 AM |
