901 transmission main seal and rear main seal |
John90290 |
Oct 17 2018, 08:31 AM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
I pulled the engine to complete the hell hole repair so figured I'd put in a new clutch. Glad I did, clutch disc soaked in oil or transmission fluid, take your pick. Also found the exhaust manifolds nuts hand tight on a couple of the studs and the thermostat cable off of the roller so that basically did not work.
Anyway.... I purchased the new seals - rear main and transmission shaft output but can't find any images or instructions on how to replace them? Usually this is straight forward but there seams to be some sort of recess in the RMS of the engine? Any diagrams or instructions would be appreciated. Also, the clutch had a lot of material left on it, almost as thick as the replacement disc so I think the clutch was recent but they never bothered to replace seals so it's shot. The flywheel looks smooth and unmarred. Do I still need to resurface? Thanks! -John |
76-914 |
Oct 17 2018, 03:43 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Don't hammer in the new rear main. You can damage one that way. There is an install tool for it but short of that you could use a flat piece of wood or metal against it. That being said there was some bit of discussion here re: which brand to buy. Evidently some were not sealing. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 12:38 PM |
