> heater blower, heater lever wire starts smoking
slotty008
post Oct 21 2018, 06:20 AM
A couple of weeks ago ,on a cold morning and driving a rally, I pulled the console heater lever to get some heat in the cockpit( never used it before). Nada! So I tried to figure out where the problem came from. Started with the blower motor : it didn't run. So I took it apart, cleaned it out, greased it and it runs freely now when I put 12V on it. But it didn't work in the car. So I checked the engine bay relay box. The heater blower relay was missing, so I ordered a new one. Still nothing. I took out the heater lever and checked the green-white wire. It looked OK to me , but as soon as I make contact with the ground , it starts smoking at the end. So there must be a short circuit somewhere.
I don't intend to take out the whole wiring harness so what can I do to fix it or where do I start looking?
rhodyguy
post Oct 21 2018, 07:04 AM
Until you sort the electrical issue out, Disconnect the fan power and cap the J tubes with rubber pipe caps from the hardware store. You'll have PLENTY of heat if the HEs are in good shape. The engine fan pressure overcomes the the aux fan pressure as engine speed increases and closes the 2 little doors on the fan shroud.
slotty008
post Oct 21 2018, 10:41 AM
QUOTE(rhodyguy @ Oct 21 2018, 03:04 PM) *
Thx for the reply.
I think one of the HE's is losing a little bit of air. I can feel a draught when I put my hand on it.(I connected the blower motor with an external 12V supply). Next week I can put the car on a lift to check it out.
But that doesn't solve my electrical problem.
slotty008
post Oct 21 2018, 12:09 PM
QUOTE(slotty008 @ Oct 21 2018, 06:41 PM) *
Thx for the reply.
I have a '75 and the fan has just one little door.
- Lo-Fi Version Time is now: 5th December 2025 - 08:42 AM
