5 lug rear kit, hubs, rotors, bearings, studs |
IronHillRestorations |
Oct 22 2018, 06:55 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
5 lug rear kit.
2- German Sebro rear 914-6 rotors 2 - SKF bearings (made in Italy) 10 - 45mm Verbus wheel studs 4 - rotor screws 2 - re-drilled rear hubs. I've been sitting on these parts for a while. One rotor had a few little spots of surface, which came off with a white bristle disc (the finest one). You'll have to get the studs pressed in. If you want to use the rotor screws, you may have to drill and tap the holes for them, but you don't have to use them. The hubs have been bead blasted (not bearing surface) and acid etched. Bearing surfaces have been polished. Check or money order preferred, but I will take PayPal if you want to add 3.5%. Shipping weight is 35 lbs, you can approximate shipping from 38363. I'll package it up, and give you the total including shipping. *** New lower price $375! *** Attached thumbnail(s) |
euro911 |
Oct 22 2018, 10:20 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Nice offering
Oct 26 2018, 12:45 PM
Bump with a lower price!
subie/914 |
Oct 26 2018, 03:49 PM
Newbie Group: Members Posts: 3 Joined: 26-October 18 From: sylmar Member No.: 22,604 Region Association: Southern California |
I Am interested / I am in the
91342 area . I will need to calculate shipping , but i do want them! 5 lug rear kit. 2- German Sebro rear 914-6 rotors 2 - SKF bearings (made in Italy) 10 - 45mm Verbus wheel studs 4 - rotor screws 2 - re-drilled rear hubs. I've been sitting on these parts for a while. One rotor had a few little spots of surface, which came off with a white bristle disc (the finest one). You'll have to get the studs pressed in. If you want to use the rotor screws, you may have to drill and tap the holes for them, but you don't have to use them. The hubs have been bead blasted (not bearing surface) and acid etched. Bearing surfaces have been polished. Check or money order preferred, but I will take PayPal if you want to add 3.5%. Shipping weight is 35 lbs, you can approximate shipping from 38363. I'll package it up, and give you the total including shipping. *** New lower price $375! *** |
forrestkhaag |
Oct 26 2018, 04:38 PM
Very nice package at a great price / having done business with IHR in the past I can attest to the high level of fit and finish to the products offered.
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/icon_bump.gif) Attached image(s) |
euro911 |
Oct 26 2018, 11:55 PM
Put me second in line
Oct 29 2018, 07:54 AM
If you don't need the rotors in the original box, I can get these in two large USPS flat rate boxes for $37.00
subie/914 |
Oct 29 2018, 03:19 PM
If you don't need the rotors in the original box, I can get these in two large USPS flat rate boxes for $37.00 That works for me ! I can get a money order to you as soon as I get an address (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:29 PM |
