WTB, Rear Brake Spring Clips |
ctc911ctc |
Oct 24 2018, 06:14 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
Mine are too corroded to put back into the car, does anyone have a pair? Thank you, CTC911CTC |
KevinW |
Oct 24 2018, 06:19 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
Please post a picture of what you need and I will check my spare parts
barefoot |
Oct 25 2018, 05:05 AM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Do you mean the little clips that hold the pins at the cable ends,
or the clips that hold the end of the brake hose, those you can find at your local FLAPS |
mankowski |
Oct 25 2018, 11:19 AM
Member Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest |
If you are talking about the springs underneath the pins on the caliper that hold the pads in place, I just did this. Porsche dealers have new ones you can buy online.
aharder |
Oct 25 2018, 11:56 AM
Advanced Member Group: Members Posts: 4,383 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Did you check with http://www.pmbperformance.com/catalog.html
ctc911ctc |
Oct 25 2018, 05:54 PM
Apologies! None of these - the "Spreader Clips" that sit on top of the brake pads and push them away from the disk when the brake pressure is off.
Do you mean the little clips that hold the pins at the cable ends, or the clips that hold the end of the brake hose, those you can find at your local FLAPS |
ctc911ctc |
Oct 25 2018, 05:55 PM
Yes, I also called them - they rebuilt all of the calipers - AND THEY LOOK AWESOME!!!! But alas, they have no clips.
ctc911ctc |
Oct 25 2018, 05:56 PM
ctc911ctc |
KevinW |
Oct 25 2018, 06:20 PM
Cary, I have two sizes. Do you need the smaller or larger ones?
ctc911ctc |
Oct 26 2018, 08:23 AM
davep |
Oct 26 2018, 08:38 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Since he is asking about rear caliper springs, I would assume the smaller ones.
Part # 311-615-269 2+1/16" long 1+11/16" wide or 53mm x 43mm I have 7 replated parts that need new rivets. |
Mr. Olympic Blue 2 You |
Oct 26 2018, 09:32 AM
Member Group: Members Posts: 134 Joined: 7-September 10 From: Puyallup, WA Member No.: 12,150 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 6th May 2024 - 07:37 AM |
