Show me your roll cage to suspension tower bracing, ..and other bracing/stiffening you've done |
naro914 |
Oct 26 2018, 08:33 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
with all the work we're doing on Papa Smurf, one of big pieces of the development is tying the roll cage to the rear and front suspension points, plus doing tubing to strengthen other points around the car.
Would like to see how people run the tubes from the roll cage, through the fire wall or window, through the engine compartment area, into the rear trunk to the shock towers. We have things in the way there, but will move around if needed.... Thanks! |
Mr. Olympic Blue 2 You |
Oct 26 2018, 12:33 PM
Member Group: Members Posts: 134 Joined: 7-September 10 From: Puyallup, WA Member No.: 12,150 Region Association: Pacific Northwest |
Good luck with the refresh Bob!
Chi-town |
Oct 26 2018, 01:11 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
That style cross brace in the halo will collapse inward on roll over ask me how I know (IMG:style_emoticons/default/sad.gif)
Here's a FIA legal one https://www.customcages.co.uk/roll-cages/porsche-914 |
naro914 |
Oct 26 2018, 01:27 PM
Nice...I could use that rotisserie...
Brett W |
Oct 27 2018, 08:06 PM
If I were doing the chassis, I would cut the current "roll cage" out altogether. I know its a pain in the ass, but there are way too many compromises in said "roll cage".
There is no lateral brace connecting the a-piillar bars at the door bar intersection and the main hoop door bar intersection. This will lead to a collapse inward should you take a hit in the door bar. The door bars will simply fold the cage up like a wet noodle. That looks like an Autopower type cage. Very old and poor design. Once you pull the dash out of the car you can push the a-pillar bars further out to properly support the front of the car. Then build a proper dash bar supports and triagulates the door bars, with the A-pillars, and the strut tower bars. You will want to go through the firewall and connect the shock towers to the a-pillars, and you want to come down to the base of the a-pillar bars to keep the front of the car from folding into your feet. As for the rear suspension you want to connect the rear shock towers to the main hoop and connect the rear suspension mounting points to the main hoop. The rear suspension mounts flex terribly and tying them into the roll cage will make the car more comfortable to drive. |
Heater Guy |
Nov 3 2018, 03:13 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
with all the work we're doing on Papa Smurf, one of big pieces of the development is tying the roll cage to the rear and front suspension points, plus doing tubing to strengthen other points around the car. Would like to see how people run the tubes from the roll cage, through the fire wall or window, through the engine compartment area, into the rear trunk to the shock towers. We have things in the way there, but will move around if needed.... Thanks! I am parting out my 914. The cage was built to FIA specs. by Matter in Germany. Side bars were added to meet SCCA requirements. The rear braces go through the rear window and attach to the shock towers. |
Krieger |
Nov 7 2018, 12:20 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Check out my F-914 build in my signature. I have Chris Foley's roll cage that I added to.
Brett W |
Nov 8 2018, 07:35 PM
That cage is of questionable legality for SCCA and NASA, probably PCA and POC as well.
Brett W |
ChrisFoley |
Nov 9 2018, 09:20 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
mlindner |
Nov 17 2018, 08:08 PM
Senior Member Group: Members Posts: 1,511 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mlindner |
Nov 17 2018, 08:34 PM
campbellcj |
Nov 18 2018, 09:29 AM
I can't Re Member Group: Members Posts: 4,540 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Heater Guy |
Dec 4 2018, 07:41 PM
with all the work we're doing on Papa Smurf, one of big pieces of the development is tying the roll cage to the rear and front suspension points, plus doing tubing to strengthen other points around the car. Would like to see how people run the tubes from the roll cage, through the fire wall or window, through the engine compartment area, into the rear trunk to the shock towers. We have things in the way there, but will move around if needed.... Thanks! This cage is legal for SCCA. Just removed it from the car. It was originally made Germany for FIA regulations. [attachmentid=677 523] Attached thumbnail(s) |
naro914 |
Dec 4 2018, 08:01 PM
Heater Guy |
Dec 4 2018, 08:05 PM
naro914 |
Dec 4 2018, 08:06 PM
^^ah. thanks
ChrisFoley |
Dec 5 2018, 06:12 AM
Without a full width main hoop crossbar that cage is not legal for SCCA Club Racing.
naro914 |
Dec 5 2018, 07:31 AM
That’s what my cage crossbar is like and it’s legal
ChrisFoley |
Dec 5 2018, 07:35 AM
Lo-Fi Version | Time is now: 25th April 2024 - 08:41 AM |
