Through-the-Hood Filler Kit |
Marek |
Oct 27 2018, 01:38 PM
Newbie Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None |
FS: Through-the-Hood Filler Kit for 914
Finally The kit contains all you need, to make your "through the hood filler look" complete with out any welding or painting !!!! the kit includeds * Original 100mm vented Blau fuel cap, in stainless steel with a 5 hole fin * A bolt on fuel neck you screw direct on to your tank , gaskets to adjust the height you can combine the gasket depending on the height you need * A "Dog bowl" to overfill fuel or rain it has a 1 m long drain tube, on top it has a rubber seal, so its tight closing against the hood, without damage * A Stainless bezel to mount on the hood, by screwing it on, with the incl 6 screws btw every bolt , screw etc you need are included incl a shortl instruction the only work you have to do your self is *messure up and drill a hole 127 mm in your bonnet , use some epoxy primer on the edge *remove the expansion tank on top of the tank by unscrewing the 8 bolts *screw on the Fuel kneck , it got the correct angle put gaskets under it to get the height ( BE AWARE YOU CAN ADJUST THE TANK IT SELF A BIT ,SO MAKE SURE ITS STRAP´ ON THIGHT BEFORE YOU DO ANYTHING ) *put on the dog bowl ,mount the gasket and drain tube ,use silicone to set the height of the dogbowl *screw on the top stainless or silver bezel with the included 6 stainless screws to the "under the hood" bezel , you might need to shorten the screws os they dont scrath the rubber seal , and use a drop of loctite to be sure the screws a lock thight A silver mat painted cap / bezel option is available , see pics later in the post For those of you that are not a fan of the screw on bezel on the hood , there is a option! For the 911 kit we offered a square adapter you see on the last picture its easy and simple and you get the perfect "hole in you hood" but its requiers welding / paint job This version is also on stock now with a Silver or polished Price 350 EURO + shipping ( to USA 37€ ) - 445 USD incl postage to US Importen Do note !!! I am shipping by DHL from Germany which is the cheapest option, I have been using them the last 10 years , so full tracking number never had a problem BUT expect up to 4 weeks delivery , DHL said its long security checks in at US customs Paypal ok, BUT save 25 EURO by a direct bank wire By interest drop me a mail early911parts@gmail.com I have posted some pictures below and much more to come ASAP Regards Marek ( Denmark ) Attached thumbnail(s) Attached image(s) |
Marek |
Oct 29 2018, 01:52 AM
Hi Guys I will post more pics asap from the instalation this week BUT It will only come in 2 finishes a polished version and a silver painted one, as on the 4th pic in the first post the cap it self is stainless , not sure you can anodize stainless but its possible to polish the cap your self ,if you want a more brusched look I did this kit also for the 911 now allmost 9 years ago and sold over 1000 pcs thanks to the magnus walker fever :-) and have seen different versions what people did to it , but I will only offer the 2 versions polished and silver painted, the silver have a satin finish to it M |
Lo-Fi Version | Time is now: 15th May 2024 - 01:55 PM |
