| boiledcabbage |
Jun 17 2005, 08:29 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 23-May 05 From: Ottawa, Canada Member No.: 4,131 |
Anyone know who manufactures these special 12 point tools? Is there an alternative?
| RAR |
Jun 17 2005, 08:33 PM
Member ![]() ![]() Group: Members Posts: 189 Joined: 24-January 04 From: Washington state Member No.: 1,598 |
VW stores carry these in blister packs. Various manufacturers I would guess. Should only cost a few (under ten, I'm guessing) bucks.
| mihai914 |
Jun 17 2005, 08:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
You can find it at NAPA part # 08714M, if you tell the guy a Volks CV bolt tool, he should know it, if not then they might as well put a monkey behind the counter!
| Dead Air |
Jun 17 2005, 08:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,273 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
The socket type I bought was $23 with tax.
There is no alternative! After checking several local auto shops I finally flagged down 2 Tool trucks, and grabbed one from the second. Mac tools was the first one. Snap-on had it! Torx do not work pipe wrench do not work vise grips do not work Make sure the "socket" is free of grease, grim or the tool will slip and getted bunged up. A local teener says If you're pulling the engine, find out which CV joint is bad and Saw through that axle, and find a new half shaft with a good CV since you have to replace it anyway. |
| joeav8tor |
Member ![]() ![]() Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
8mm triple square...got mine at napa
| SirAndy |
Jun 17 2005, 08:58 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
and don't forget to put on new gaskets every time you take the CVs off ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
| boiledcabbage |
Jun 17 2005, 09:01 PM
thx - will find one - am about to change rear wheel bearing - hub gets quite 'warm' after a short trip
Pelican tech article on wheel bearing removal looks like fun... |
| Type 4 Unleashed |
Jun 17 2005, 11:10 PM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Snap On, is the way to go, when it does get stripped, grab a Snap On truck, they'll pop out the old one, hammer in a new one, for free, I don't think NAPA does that. The real small pair of vise grips, do work, if you have a cv bolt, thats already stripped (PO) clamp it on, tap it with a hammer, comes right off. Make sure all the cv bolt washers are there, they keep the bolts from coming loose. And before you take the cv bolts out, take a little screw driver and clean out the bolt heads, and then spray them with some Brakleen, and final tip, before you take each bolt out, tap the socket into each bolt, it pushes out any crap you couldn't clean. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Lo-Fi Version | Time is now: 8th December 2025 - 05:21 PM |
