Has anyone else experienced trouble, with new windshield trim clips breaking? |
ChrisFoley |
Nov 1 2018, 02:10 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We have to remove a brand new windshield to replace all the New trim clips made by a popular vendor. They're so brittle they all break as soon as you try to install the trim. (IMG:style_emoticons/default/WTF.gif)
More than 3 hours of labor generated by using substandard parts. Seems unfair to charge my customer and I'm not happy about eating that either, except that I'm the one who recommended the vendor. Never again. (IMG:style_emoticons/default/dry.gif) Buyer beware. I'm going back to Genuine Porsche. |
jsaum |
Nov 4 2018, 05:28 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I’ve been in the plastic injection molding industry for 36 years. Some of things I would look at is the same material being used. Are you using recycled materials or too high of a mix of reground material. Also compare where the OEM part is gated to your part. Direction of flow will determine part strength. Material can become degraded if it is being processed in to large of a machine. PM me if you have questions or can’t find a cause. I would be glad to look at some parts for you.
davep |
Nov 8 2018, 09:05 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Some of things I would look at is the same material being used. Are you using recycled materials or too high of a mix of reground material. Also compare where the OEM part is gated to your part. Direction of flow will determine part strength. Material can become degraded if it is being processed in to large of a machine. PM me if you have questions or can’t find a cause. I would be glad to look at some parts for you. Very good advice. Gating is very important. Also the processing temperature and timing can cause degradation. We had a poor supplier that made polypropylene tubs that were as fragile as glass instead of being tough. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:02 AM |
