Has anyone else experienced trouble, with new windshield trim clips breaking? |
ChrisFoley |
Nov 1 2018, 02:10 PM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We have to remove a brand new windshield to replace all the New trim clips made by a popular vendor. They're so brittle they all break as soon as you try to install the trim. (IMG:style_emoticons/default/WTF.gif)
More than 3 hours of labor generated by using substandard parts. Seems unfair to charge my customer and I'm not happy about eating that either, except that I'm the one who recommended the vendor. Never again. (IMG:style_emoticons/default/dry.gif) Buyer beware. I'm going back to Genuine Porsche. |
Mikey914 |
Nov 4 2018, 08:39 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We did do our gating differently. And we do a a percentage of recycled material that is used. we can run virgin, and or change to a glass infused delrin. I'm thinking that we will do a preliminary and see when everything falls, possibly utilizing a better material. The feed back we have received on was mostly very good, but even if there is a small problem we will fix it. We also have an idea for a way to check fitment prior to glass being installed that would be handy too.
jsaum |
Nov 8 2018, 10:18 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
We did do our gating differently. And we do a a percentage of recycled material that is used. we can run virgin, and or change to a glass infused delrin. I'm thinking that we will do a preliminary and see when everything falls, possibly utilizing a better material. The feed back we have received on was mostly very good, but even if there is a small problem we will fix it. We also have an idea for a way to check fitment prior to glass being installed that would be handy too. Plastic molecules align in the direction of flow and are strongest in that direction and weakest in the opposite. If you can tell me the grade I can take a look at the material data sheet. You’ll want a material that has a good flexural modulus. Also look at the elongation at break numbers. I would think an Nylon 66/ ST801 might be a good choice for these parts. Gf delrin might be too brittle. Any GF content isn’t going to allow the part to flex. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:04 PM |
