Has anyone else experienced trouble, with new windshield trim clips breaking? |
ChrisFoley |
Nov 1 2018, 02:10 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We have to remove a brand new windshield to replace all the New trim clips made by a popular vendor. They're so brittle they all break as soon as you try to install the trim. (IMG:style_emoticons/default/WTF.gif)
More than 3 hours of labor generated by using substandard parts. Seems unfair to charge my customer and I'm not happy about eating that either, except that I'm the one who recommended the vendor. Never again. (IMG:style_emoticons/default/dry.gif) Buyer beware. I'm going back to Genuine Porsche. |
Mikey914 |
Nov 10 2018, 12:36 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We've done some research on these over the last few days and are making some modifications.
Our conclusion is that yes these can be used it's not impurities in the material that is causing the issue. There is a very slight step in the mold that is more critical in tolerance than we had realized. It actually holds the clip just slightly off the mounting surface. It it is pushed past this the entire clip rests fully on the body. This takes up some of the tolerance needed to push the aluminum clip in. We have a solution that should work better and allow for no clip breakage when you go to install the trim. We are revising our product to include the spacers that are flexible, and including a piece of windshield trim (that we also make) about 2" so that you can test each clip prior to windshield install. we used this technique yesterday successfully without breakage, but will be including these in a kit of 25 with the test piece for the same price as just the 19 clips. I will have Matt post up more on this this next week. ..now back to the new airplane. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:16 AM |
