Yeah, I'm still a newbie. – Warning light question |
Tdskip |
Nov 2 2018, 01:41 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So I did search on this but did not find in answer, so what the heck, thought I'd ask...
I am starting to use that 1973 1.7 car that I bought on Bring a Trailer and so far so good. My gas gauge is showing half a tank but the orange light next to the pointer remains illuminated. I'm assuming this is my low fuel warning light after checking the diagrams but would like to doublecheck. Thanks for all of the help. |
Tdskip |
Nov 7 2018, 07:32 AM
Just to close this out-I put fuel in the tank yesterday and you could hear her that the tank was basically empty, so you guys nailed it that I should trust the light over the needle indicator.
Thanks for the tip on what I can do to potentially address this George, you and the rest the people here have been just outstanding in the support you provide the community. Thank you |
Spoke |
Nov 7 2018, 10:25 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
...I should trust the light over the needle indicator. I don't trust either. When the tank gets to 1/2 empty I fill up. The sender is a linear resistor but the tank volume is not linear from top to bottom. The top of the tank is much larger than the bottom of the tank. Below 1/2 tank on the gauge the fuel level drops quicker. As mentioned above, remove the sender from the tank, remove the cover and inspect. There are a couple of very thin wires which are the resistor that runs from the top to the bottom of the sender. These may need cleaned. The float needs to move effortlessly up and down on these wires. Be careful as the wires can be damaged very easily. A new sender is > $100 on Pelican. |
914_teener |
Nov 8 2018, 08:33 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
...I should trust the light over the needle indicator. I don't trust either. When the tank gets to 1/2 empty I fill up. The sender is a linear resistor but the tank volume is not linear from top to bottom. The top of the tank is much larger than the bottom of the tank. Below 1/2 tank on the gauge the fuel level drops quicker. As mentioned above, remove the sender from the tank, remove the cover and inspect. There are a couple of very thin wires which are the resistor that runs from the top to the bottom of the sender. These may need cleaned. The float needs to move effortlessly up and down on these wires. Be careful as the wires can be damaged very easily. A new sender is > $100 on Pelican. But the lines are not equally spaced? |
Lo-Fi Version | Time is now: 4th May 2024 - 12:48 PM |
