Sickness |
Sickness |
Targa70 |
Nov 3 2018, 07:46 PM
Member Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None |
Yes it is a sickness; and I believe other World members have it. I went so far as to transfer the stickers and felt bad from my broken fan housing to the new one. Only I will know.
Inspired by the crew here, I spent more hours than I should have on my blower. Though a hidden part, I am happy with my results. I started with my original system paired with a donor system I purchased several years ago. I used Easy-Off to remove most all of the overspray, followed by a combination of 1000, 2000, Autsol, and Magic Eraser. New 914 Rubber seals and plated hardware finished if off. [attachmentid=673 593] Attached thumbnail(s) |
TravisNeff |
Nov 3 2018, 08:04 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Nice work!
raynekat |
Nov 3 2018, 08:11 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Not sick........awesome!
bbrock |
Nov 3 2018, 08:59 PM
Love it!!! (IMG:style_emoticons/default/smilie_pokal.gif)
And here is my favorite part: I went so far as to transfer the stickers and felt bad from my broken fan housing to the new one. Only I will know. (IMG:style_emoticons/default/thumb3d.gif) |
PlaysWithCars |
Nov 3 2018, 10:50 PM
Senior Member Group: Members Posts: 523 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Damn. That looks awesome! Bet you're tempted to get another one to install in the hidden spot under the cowl and mount this one in the trunk where it can be admired.
wes |
Nov 4 2018, 01:39 AM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
defianty |
Nov 4 2018, 03:59 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Nice job. You're not alone, I also suffer the same sickness. (IMG:style_emoticons/default/lol-2.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1541325547.1.jpg) |
914Sixer |
Nov 4 2018, 05:54 AM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Nothing better than done correctly. (IMG:style_emoticons/default/smilie_pokal.gif)
tmc914 |
Nov 4 2018, 09:10 AM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
Wow, looks new.
Lucky9146 |
Nov 4 2018, 09:20 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,605 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Dang! That's nice!
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Literati914 |
Nov 4 2018, 10:43 AM
Senior Member Group: Members Posts: 1,433 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
A tutorial? for those of us who are happily 914 sick. Those plastic pieces weren't just/only cleaned, right ? (IMG:style_emoticons/default/pray.gif)
PanelBilly |
Nov 4 2018, 11:48 AM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
You’re making me want to tear mine apart again to detail it.
Stop it! |
bbrock |
Nov 4 2018, 01:27 PM
You’re making me want to tear mine apart again to detail it. Stop it! Ditto. Mine cleaned up nice but rather than have the hardware replated, I just painted them. After seeing Stephen's work, I decided I'd tear it apart again and send the hardware for plating. Now with this, I HAVE to! (IMG:http://www.914world.com/bbs2/uploads/post-20845-1496680902.jpg) |
rgolia |
Nov 5 2018, 07:38 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Love it, but I would have to make two of them because there is a good chance that the first one I try to install will end up flying across the garage in a fit of rage
Cairo94507 |
Nov 5 2018, 07:44 AM
Michael Group: Members Posts: 9,708 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That is a sickness we all enjoy. (IMG:style_emoticons/default/beerchug.gif)
Targa70 |
Nov 5 2018, 08:47 AM
Since a few members have asked, here is how I did it without using paint. I carefully removed all the metal clips and pulled the cases apart exposing the fan and the flapper valves. I believe the nuts/bolts on the flappers were 8mm. I removed the fan sensor, cleaned the contacts, and lightly brushed off the fan blades. These blades are thin, brittle, and easy to break.
While all the metal parts were getting yellow zinc'd, I ordered the 914rubber seals and removed the overspray with Easy-Off oven cleaner. I did not let the Easy-Off sit for very long before I hosed it off and the easy off makes the paint easy to scrape/sand off. I then used 1000 and 2000 grit, in that order, to wet sand most of the scratches, and dullness left by the Easy-Off. I used Magic Eraser and Autosol, sometimes together and sometimes alone, with great success to get to the areas that I could not with the sand paper. And I used a lot of elbow grease. I used a soft toothbrush to clean up the areas close to the letters and in the cracks. When the clips arrived I reversed the process, being very careful to not break the fragile plastic. I used my original system from an early car and some common parts from a later car. I plated as much as I could and sold all the leftovers to help offset my costs. |
doug_b_928 |
Nov 6 2018, 05:25 PM
Senior Member Group: Members Posts: 689 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Really nice job! I plan to do a similar job (without the plating) this winter. I'm curious, does the easy off somehow not remove the black paint below the overspray in a way that laquer thinner would?
ValcoOscar |
Nov 6 2018, 05:29 PM
Garage Life Group: Members Posts: 2,374 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif)
@914_7T3 Functional ART!!!! Oscar |
jim_hoyland |
Nov 6 2018, 06:21 PM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Any paint ? The plastic looks great ! Nice work (IMG:style_emoticons/default/smile.gif)
bbrock |
Nov 6 2018, 06:43 PM
Really nice job! I plan to do a similar job (without the plating) this winter. I'm curious, does the easy off somehow not remove the black paint below the overspray in a way that laquer thinner would? Unless a PO painted it, there is just black plastic under the overspray - no paint. Anything that softens paint without damaging the plastic will work. I used brake fluid but it was a slow, messy process and brake fluid is not fun to work with. |
Lo-Fi Version | Time is now: 24th April 2024 - 04:56 AM |
