Sickness |
Sickness |
Targa70 |
Nov 3 2018, 07:46 PM
Member Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None |
Yes it is a sickness; and I believe other World members have it. I went so far as to transfer the stickers and felt bad from my broken fan housing to the new one. Only I will know.
Inspired by the crew here, I spent more hours than I should have on my blower. Though a hidden part, I am happy with my results. I started with my original system paired with a donor system I purchased several years ago. I used Easy-Off to remove most all of the overspray, followed by a combination of 1000, 2000, Autsol, and Magic Eraser. New 914 Rubber seals and plated hardware finished if off. [attachmentid=673 593] Attached thumbnail(s) |
doug_b_928 |
Nov 6 2018, 05:25 PM
Really nice job! I plan to do a similar job (without the plating) this winter. I'm curious, does the easy off somehow not remove the black paint below the overspray in a way that laquer thinner would?
bbrock |
Nov 6 2018, 06:43 PM
Really nice job! I plan to do a similar job (without the plating) this winter. I'm curious, does the easy off somehow not remove the black paint below the overspray in a way that laquer thinner would? Unless a PO painted it, there is just black plastic under the overspray - no paint. Anything that softens paint without damaging the plastic will work. I used brake fluid but it was a slow, messy process and brake fluid is not fun to work with. |
worn |
Nov 17 2018, 04:47 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Really nice job! I plan to do a similar job (without the plating) this winter. I'm curious, does the easy off somehow not remove the black paint below the overspray in a way that laquer thinner would? Unless a PO painted it, there is just black plastic under the overspray - no paint. Anything that softens paint without damaging the plastic will work. I used brake fluid but it was a slow, messy process and brake fluid is not fun to work with. You guys got it bad. Only cure is cowbell. If that. Also to original poster, well done! |
Lo-Fi Version | Time is now: 27th April 2024 - 06:25 PM |
