Wires for oil temp sensor into engine bay ?, Green wire with black stripe in harness but not on relay board junctions |
barefoot |
Nov 4 2018, 08:39 AM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Car is 76 with new late wiring harness. Initial wiring checkout after harness install.
Turn signal on, front & rear run lights flash as intended but signal light on tach just comes on once momentarily. Is this normal, or do I have a wiring issue ?? Well, i tried all 5 of my stash of flasher relays, several showed same symptom of single flash, but 1 worked OK. Now the hi beam indicator bulb works fine but does not show thru to front of Tach, Don't know whats up with this |
Lo-Fi Version | Time is now: 18th May 2024 - 06:34 PM |
