As promised : A couple shots of repairing the frunk seal channel |
cary |
Nov 4 2018, 09:09 AM
It's been a while seen I made the promise to show shots of repairing the frunk seal channel. Taylor's car has 3 or 4 spots that need attention.
After doing the same repairs on Doug's car I determined there has to be an easier and faster way. So I asked Mark @ 914 Rubber about making up some metal strips with the correct flange/lip made up. Like always, he was quick to oblige. Here's what I got. Sorry, forgot to measure for dimensions. It's been a while. But they are a prefect fit for both the narrow and wide pieces. First order of business. Fixing the rotted out corner. Can't say enough about the control I have with my MillerMatic 141. There's 3 more to do on the other side. |
cary |
Nov 4 2018, 09:24 AM
Now onto the section that most car's have an issue with.
Cut with a metal band saw. Holes punched with my punch/flange tool. That was the easy part. I'm still using too coarse of a belt on the sander. Problem is, the weld is harder than the parent material. I have a box of 3m Cubitron coming to see if they work a little better. They cost twice as much, but maybe they'll last longer than 15 seconds. I'm trying to go too fast , but time is money. Patched the hole on the bottom with a piece of 18 ga. This new toy makes short work of making patch pieces. That was the easy part .................. |
bbrock |
Nov 4 2018, 09:39 AM
Nice! I've been using the 3M Cubitron belts in my cheap HF 3/8"x13" sander. The 80 grit belts are fantastic and seem to last forever. 36 grit are a complete waste of money. Maybe I got a bad batch, but the grit flies off the belt in the first 30 seconds of use. Completely worthless. The 80 grit belts cut so clean and fast that I didn't have much need for the coarser grit anyway.
RickS |
Nov 4 2018, 09:41 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Very skillful work. Well done.
cary |
Nov 4 2018, 09:43 AM
Now onto the long section on the left that was cut out some time ago.
It's unbelievable how small the lip is that the fender sits on. But in this case the lip was cut while cutting out the rotten sections. Once again cant say enough about my MillerMatic 141 with Easy Grind wire. Isn't quite as lumpy as it looks in the picture. Hopefully I can find some 80 gr for my 1/2 belt that will lasts longer than 3 seconds on the welds. Now on another piece of Mark's channel patches. Having the channel with the exact correct width and height makes short work of it. Here's where I'll start next week. Short day, family birthday dinner. |
cary |
Nov 4 2018, 09:57 AM
Nice! I've been using the 3M Cubitron belts in my cheap HF 3/8"x13" sander. The 80 grit belts are fantastic and seem to last forever. 36 grit are a complete waste of money. Maybe I got a bad batch, but the grit flies off the belt in the first 30 seconds of use. Completely worthless. The 80 grit belts cut so clean and fast that I didn't have much need for the coarser grit anyway. I have a box 36 gr coming to test. I'll order a box of 80 gr in a couple minutes. Its not very funny how fast the 36gr disappear. (IMG:style_emoticons/default/sad.gif) Hopefully I'll get the finish I want with the 80gr. |
cary |
Nov 4 2018, 10:00 AM
Hopefully Mark will chime in on the cost and inventory of the strips.
Plan to go to Home Depot this afternoon and look at Dremel cutting and finishing tools. |
jesse7flying |
Nov 4 2018, 10:16 AM
Member Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None |
+1 on the cost and inventory of the repair strips. I've been wondering for a while. Great work Cary!
Nov 4 2018, 01:52 PM
Is it just the lighting, or did I see a brazed corner in that second pic?
--DD |
cary |
Nov 4 2018, 02:43 PM
It's just the lighting. Haven't run into any sparklers. LOL.
sixnotfour |
Nov 4 2018, 03:44 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Nov 4 2018, 04:56 PM
PlaysWithCars |
Nov 4 2018, 08:09 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I'm faced with this same repair need on my car so I'm watching with interest. How did you stretch/shrink flanges to match the compound curves along the seal channel? Particularly along the front, other threads have made it look like there is a lot more shape than one would think.
cary |
Nov 4 2018, 08:26 PM
It takes just a smidgen to get the arc you need. |
Mikey914 |
Nov 4 2018, 08:47 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PlaysWithCars |
Nov 5 2018, 10:59 PM
cary |
Nov 7 2018, 09:16 AM
A couple shots of finishing up on Monday afternoon.
Stated with the little patches above the right head light bucket. All these patches were done with the strips created 914 Rubber. The 8" shear made it a little easier. But it cuts real easy with a pair of yellow tin snips. Didn't run into any brazing in the corners. Finished up the long patch on the left channel. Not quite totally finished. Waiting for the new 3m sanding belts. |
Lo-Fi Version | Time is now: 20th May 2024 - 05:06 PM |
