Good news ...Bad news, Helo needed |
simonjb |
Nov 4 2018, 11:17 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
So the good news is that I managed to get the new engine started today. She fired right up after a crank or two and ran great!! First time in 2 years...
Then, I noticed the alternator light was on -RED. Then I noticed a bunch of smoke from the engine bay. Turned her off and...The red wire from the starter to the alternator was red hot and burning...it burnt all the way to the alternator from the starter....... The battery was also making strange noises....and was very warm When I got the engine the harness was already connected. I connected the longer end to the starter. and also plugged it in to the relay board Sounds like something wasn't connected right? Perhaps the red wire wasn't connected correctly to the alternator? |
sixnotfour |
Nov 6 2018, 02:42 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
from samba
template for alternator gasket 021903637 / 021 903 637 Print out at 300dpi and you're good to go. Attached thumbnail(s) |
simonjb |
Nov 6 2018, 03:50 PM
mgphoto |
Nov 28 2018, 12:13 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
from samba template for alternator gasket 021903637 / 021 903 637 Print out at 300dpi and you're good to go. Thanks Gasket doesn’t prevent shorting, only seals for air to be directed away from the alternator, the long screws still provide a path to ground. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:23 PM |
