F/S '73 914 2.0, Excellent condition. SOLD |
kgruen2 |
Nov 6 2018, 02:49 AM
Member Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region |
I'm selling my '73 914 2.0, rust free, White with Black interior, stock looking exterior, minor mods in the interior. Car had been repainted prior to my purchase in Jan. 2015. The following work has been done since the summer of 2015:
The engine was rebuilt, utilizing the original numbers matching case, by Raby Air-Cooled Technology to 2270SR specs (2270 cc), dual 44 IDF Carbs, Mallory Unilite Distributer, new clutch and pressure plate, balanced to race specs, powder coated tins and cooling system. Engine dynoed at 178 hp @ 6400rpm, 164 ft.lbs. torque at 4900 rpm. Raby Certificate of Authenticity. Engine has approx 12,000 miles since rebuild. New firewall pad and engine compartment seals. "Tuna can" oil sump with extended (lower) oil pick-up tube. New stainless steel Heat Exchangers and heater tubes and control valves. Borla stainless steel dual tip muffler. (Very rare, only between 10-20 made). New starter. Front mounted oil cooler with dual fans (thermostatically controlled), remote oil filter, utilizing aviation quality oil lines and hardware. Total oil capacity is 6 qts. Complete fuel system O/H (tank dipped and sealed, 3/8" stainless steel fuel lines from front to back, new Mallory fuel pump, aviation quality fuel lines and hardware). There are three fuel filters, one before the fuel pump and one before each carb. New stock spec KYB shocks. New Good Year Eagle Sport 195/65 tires, balance and 4-wheel alignment (less than 1000 miles). Turbo tie-rod ends were installed when the tires were replaced. New master cylinder (17mm), rebuilt rear calipers, new brake pads front and rear, fresh brake fluid. Digital instruments, cyl head temp, oil temp, and volt meter, in center console (can easily be converted back to analog for that original look). Toggle switches for fuel pump, starter, and windshield washer fluid (converted to electric pump), (can easily be converted back to stock configuration). Refurbished Blaupunkt AM/FM radio w/ two new speakers (for that original look and sound). Optima Red gel battery (no acid leaks). Speedometer O/H by N. Hollywood Speedometer (odo did not work). Right outside mirror installed, left outside mirror replaced. Original first print edition owner's manual in excellent condition. Have receipts for all the work performed. Porsche Certificate of Authenticity. This is not a garage queen, but a great looking and fun car that can be used as a daily driver with an engine that has a very strong mid-range and that pulls easily to red-line. An 8 out of 10 cosmetically. A 9.9 out of 10 mechanically. Car needs nothing but your personal touch. PPI welcomed/encouraged. Have about $60k invested. You can text me at (805)279-7815 or e-mail at kgruen2@aol.com More pics on request. Attached thumbnail(s) Attached image(s) |
ValcoOscar |
Nov 6 2018, 08:03 AM
Garage Life Group: Members Posts: 2,374 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I saw this car up close back in April at our 2018 Route 66 gathering.
Truly well put together, prospective buyer will not be disappointed. Owner couldn’t have been nicer. Both of our cars have that exact same Raby engine so surely a blast to drive. Someone here please buy this beauty. I can assist in trailering this car to SoCal if needed. My P Hauler is ready!!! (IMG:style_emoticons/default/white914.jpg) Oscar |
kgruen2 |
Nov 6 2018, 04:00 PM
I saw this car up close back in April at our 2018 Route 66 gathering. Truly well put together, prospective buyer will not be disappointed. Owner couldn’t have been nicer. Both of our cars have that exact same Raby engine so surely a blast to drive. Someone here please buy this beauty. I can assist in trailering this car to SoCal if needed. My P Hauler is ready!!! (IMG:style_emoticons/default/white914.jpg) Oscar Hi Oscar. Congrats on your car being the Car of the Month. Thank you for the kind words. Karl |
kgruen2 |
Nov 6 2018, 10:51 PM
Per request, more pics:
Attached thumbnail(s) |
kgruen2 |
Nov 19 2018, 09:54 PM
Recent work completed by Patrick Motorsports in Dec. 2018. Replaced stock engine mounted oil cooler. Cleaned up some electrical wiring while engine was out. Re-mounted the fuel pump (much quieter now) and replaced weeping fuel lines.
e-mail: kgruen2@aol.com or call/text (805)279-7815 |
kgruen2 |
Nov 19 2018, 09:55 PM
Must sell. Priced accordingly. $22.5k (that's how much I have in the engine and exhaust system alone.)
e-mail: krguen2@aol.com or call/text (805)279-7815 |
kgruen2 |
Nov 23 2018, 08:51 PM
MikeInMunich |
Nov 24 2018, 09:32 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Awesome deal with that engine! (IMG:style_emoticons/default/drooley.gif)
Wish I was in the market / could buy it! (IMG:style_emoticons/default/sad.gif) GLWTS! (IMG:style_emoticons/default/beerchug.gif) |
soccerplyr |
Dec 13 2018, 08:17 PM
Newbie Group: Members Posts: 25 Joined: 31-August 13 From: Sandy, Utah Member No.: 16,329 Region Association: Rocky Mountains |
My Dad saw you driving today and chased you down in his truck so he could take pictures to send me. Hahaha. He said the car looks great and he was glad he didn't run into you will driving and taking pictures.
kgruen2 |
Dec 16 2018, 04:03 AM
My Dad saw you driving today and chased you down in his truck so he could take pictures to send me. Hahaha. He said the car looks great and he was glad he didn't run into you will driving and taking pictures. I did see someone in a truck taking pics. Glad you liked them. The car does look great in person. (IMG:style_emoticons/default/beerchug.gif) |
kgruen2 |
Jan 12 2019, 06:31 PM
Bumped.
Jazzy |
Jan 17 2019, 03:25 PM
Newbie Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe |
Email sent.
Lo-Fi Version | Time is now: 24th April 2024 - 08:52 AM |
