Repair Seal Surface on Case, Thoughts for fixing PO's handiwork |
BeatNavy |
Nov 6 2018, 03:29 PM
Rebuilding the 1.7L that came with my '72, and it looks like the case has been split before. A previous repair or rebuild effort left these scars on the case where the front pulley seal rides.
Any ideas on how to fix or at least prevent leaks? One side of case: And the other: |
Chi-town |
Nov 6 2018, 03:33 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
A little extra sealant should take care of it.
If you want to get crazy with it, have it welded and re-machined |
BeatNavy |
Nov 6 2018, 03:47 PM
Mblizzard |
Nov 6 2018, 04:09 PM
A little extra sealant should take care of it. If you want to get crazy with it, have it welded and re-machined Ok, cool, thanks. Any thoughts on a little JB Weld and careful sanding, or is that more likely to do more harm than good? JB weld is never as welded as you would think. Sand it down so there are no rough edges to cut the seal and take the extra sealant route and I doubt you will have any issues. |
mb911 |
Nov 6 2018, 06:52 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
A little extra sealant should take care of it. If you want to get crazy with it, have it welded and re-machined Ok, cool, thanks. Any thoughts on a little JB Weld and careful sanding, or is that more likely to do more harm than good? JB weld is never as welded as you would think. Sand it down so there are no rough edges to cut the seal and take the extra sealant route and I doubt you will have any issues. (IMG:style_emoticons/default/agree.gif) |
BeatNavy |
Nov 6 2018, 08:14 PM
Thanks, fellas. Sounds like the "right" answer is also a fairly easy one (I like when that happens). I'll go the light sanding and sealant route.
McMark |
Nov 7 2018, 05:12 AM
Yup. Smooth any burrs or sharp edges, and run it.
Lo-Fi Version | Time is now: 20th May 2024 - 07:10 PM |
