New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Chi-town |
Nov 7 2018, 09:03 AM
A blacktop is nice but parts are getting harder and harder to get. I just did one in an AE86. I would look into a K series if you want a reliable powerplant with inexpensive parts. I definitely considered the K series motors. Its no doubt the more practical option.. cheaper, can make much more power, more reliable even. The only advantage the 4AGE has is size, sounding better and being a cooler swap. And that pretty much does it for me. But I'd no doubt have to get some seat time in like a Civic Si or RSX type S or something, to see if I'd like that motor. I did love the sound of the ITBs screaming but you can get that same sound from a K20 with ITBs. The thing that really hurts the blacktop and silvertop swaps is the water line issue. I ran the RS Chita setup in my 86 which made life easy at the price of $400. I looked at the SQ engineering kit but it was still a bit too rough for my taste. At least you won't need to relocate the dizzy so that saves you a few $$. If you do decide to do a BT20v let me know as I have a brand new set of performance spark plug wires I imported sitting on a shelf for it. |
Lo-Fi Version | Time is now: 19th April 2024 - 08:30 PM |
