New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
betz |
Nov 10 2018, 06:17 PM
I've been sick the past few days, but I couldn't help but fuss with the 914 a bit.
Got a couple of suspicious things going on. I plugged the fuel pump in, but with the ignition on it does not power the fuel pump. I have the supply line disconnected, and even tried cranking but no fuel is coming out. Tested voltage at the fuel pump plug, I'm reading 6V. Don't know why it's not 12.. and seems a little suspicious that it's exactly half. Tomorrow I'll try putting in the new bosch 69133 fuel pump. If it doesn't work ill just jump the wires... maybe put a switch in like a race car lol. But yeah, at this point I'm thinking, sort out the fuel pump and It'll probably run. Hopefully. |
Chi-town |
Nov 11 2018, 01:48 PM
I've been sick the past few days, but I couldn't help but fuss with the 914 a bit. Got a couple of suspicious things going on. I plugged the fuel pump in, but with the ignition on it does not power the fuel pump. I have the supply line disconnected, and even tried cranking but no fuel is coming out. Tested voltage at the fuel pump plug, I'm reading 6V. Don't know why it's not 12.. and seems a little suspicious that it's exactly half. Tomorrow I'll try putting in the new bosch 69133 fuel pump. If it doesn't work ill just jump the wires... maybe put a switch in like a race car lol. But yeah, at this point I'm thinking, sort out the fuel pump and It'll probably run. Hopefully. Check all your fuses and all the connections at the relay board in the engine bay. Actually disconnect them and inspect them closely. Also check all your grounds and make sure they are clean and tight. There may be a seat belt ignition interrupt under the passenger seat also. You can bypass it buy connecting the two big yellow wires. |
Lo-Fi Version | Time is now: 23rd April 2024 - 08:39 AM |
