New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Dave_Darling |
Nov 12 2018, 04:33 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
First: FUEL LEAKS BAD!!! Make sure you deal with that; too many of these cars have burned to the ground.
Second: A hanging idle is often caused by timing that is too far advanced. If the centrifugal advance weights stick, which they can do after a few decades, that can cause this. Also having the vacuum dashpot hooked up wrong can do it. Vacuum leaks are another possibility, as they generally cause high idle. --DD |
betz |
Nov 12 2018, 08:15 PM
First: FUEL LEAKS BAD!!! Make sure you deal with that; too many of these cars have burned to the ground. Second: A hanging idle is often caused by timing that is too far advanced. If the centrifugal advance weights stick, which they can do after a few decades, that can cause this. Also having the vacuum dashpot hooked up wrong can do it. Vacuum leaks are another possibility, as they generally cause high idle. --DD I mean, the fuel pump only leaked when jumping the wire. Still, I already have the new one and will be putting it in for sure. I'll be looking at the ignition and distributor next. After driving the 914 I think I might just go a different direction for engine swaps. Super cheap.. but still cool. Subaru Frankenmotor- the 2.5L with 2.2 SOHC heads, give it some nice cams, 3 angle valve job, maybe some mild porting. Good for about 200hp. I can easily buy the engine pieces opportunistically, and save a lot of money. This'll make me feel better about investing towards some fun stuff.. maybe ITB's? :0 I was even thinking of using the EJ251 harness & ECU because it already runs off a MAP... |
Andyrew |
Nov 12 2018, 09:38 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
After driving the 914 I think I might just go a different direction for engine swaps. Super cheap.. but still cool. Subaru Frankenmotor- the 2.5L with 2.2 SOHC heads, give it some nice cams, 3 angle valve job, maybe some mild porting. Good for about 200hp. I can easily buy the engine pieces opportunistically, and save a lot of money. This'll make me feel better about investing towards some fun stuff.. maybe ITB's? :0 I was even thinking of using the EJ251 harness & ECU because it already runs off a MAP... Peter has that swap, great running car with sensible power. I've got a video of a drag race between him and when I had a V8 swap. The weight difference and agression off the line for his car meant that he kept up with me to about 60mph when I started to pull on him. I would totally agree with that kind of swap. The more time behind the wheel of a 914 the better (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 11:49 AM |
