New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
betz |
Nov 26 2018, 06:34 PM
Thanks for the reply Dave.
I just made a black friday order of 914rubber for some houndstooth seats and a loop carpet set! Still working on making the car driveable in the meantime. Was wondering... Does anyone know about doing a swap with the Subaru / Toyota FA-20 engine found in the FR-S/BRZ/86? I haven't seen a single thread on here where someone has done that. But it seems like an obvious choice to me to someone who wants revs, 200hp N/A, and a nice reliable modern motor. Plus, the FA20 is about to be in it's heyday for aftermarket, as BRZs get more and more affordable. The aftermarket is already quite good. Yeah I mean, they're more pricey motors marginally ($2-3k at first glance), but I'm also working with essentially a brand new high performance motor and won't have to do anything in the way of engine refresh and internal modification. Doing some searching, it might even bolt up to other subaru transmissions, and therefore work with all of the Subaru swap stuff currently on the market. I'm not sure though. I would wonder if anything engine mount / transmission related is different. In any case I think this motor would look very right in a 914 engine bay... (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1543278884.1.jpg) |
Lo-Fi Version | Time is now: 20th April 2024 - 04:52 AM |
